Bone stock 90 GT - 10mpg??
87lc2
214
Hey guys, just bought this car about 3 weeks ago for my fiance. Bone stock 90 GT. She only drives like 6 miles a day so the first tank of gas lasted a while. When she filled it yesterday it took 11.3 gallons and there was 114 miles on the trip = 10.09 mpg. Car just passed emissions here in PA with flying colors. I have done a full tune-up on the car; fuel filter, air filter, pcv, plugs, wires and the car runs excellent. All of her driving is city driving but 10mpg, seriously? Where should I start? When I took the old plugs out they looked great, just a light brown color. Pulled a plug last night (2 weeks old), and it looks brand new. Car doesnt seem to be running pig rich or anything. Is it possible that its only getting the 10 mpg because all of the driving is city driving and the car barely gets warmed up before she gets to the office? Not really a big deal as far as gas money in concerned since she drives so little, but want to make sure the car is running its best. Any input appreciated, TIA.
If you haven't, pull codes for peace of mind. Otherwise, it sounds quite reasonable to me. If you guys ever get out for a weekend trip or some highway driving, mileage should go way up.
Yea, I was planning on taking it to work one day next week (about 70 miles round trip highway) and ill see what that does for me. I've had 3 5.0 cars through the years and i remember getting about 15 mpg, but never this low. Im guessing its most likely due to the type of driving she's doing. Will definitely pull the codes to see if theres anything hidden in there.
i have had good luck with seafoam. try putting a can of that in with a full tank. im thinking along the lines of mike with a bad injector too.
fwiw, i just got 130 miles on half a tank with my 425+ rwhp notch in the city. i've got atleast 5 pulls with my foot in the radiator on that tank too.
An inoperative injector would be noticeable and would not allow a car to pass emissions with flying colors.
Take into account any long stays in drive-thru lines and long redlights, at which time you are essentially getting 0 MPH. Also if the car has the original cats, could they possibly be clogged (in which case you would be down on power as well) ?
Cylinder balance test:
Revised 21-Nov-2010 to improve readability of the cylinder balance test.
Warm the car's engine up to normal operating temperature. Use a jumper wire or paper clip to put the computer into test mode (see dumping the codes below).
Start the engine and let it go through the normal diagnostic tests, then quickly press the throttle to the floor. The engine RPM should exceed 2500 RPM's for a brief second. The engine RPM's will increase to about 1450-1600 RPM and hold steady.
The computer will then shut off each injector, one at a time. When it has sequenced through all 8 injectors, it will flash 9 for everything OK, or the number of the failing cylinder such as 2 for cylinder #2. Quickly pressing the throttle again up to 2500 RPM’s will cause the test to re-run with smaller qualifying figures. Do it a third time, and if the same cylinder shows up, the cylinder is weak and isn’t putting out power like it should.
See the Chilton’s Shop manual for the complete test procedure.
Dumping the computer trouble codes
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
If your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method.
There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Do a compression test on all the cylinders.
Take special note of any cylinder that shows up as weak in the cylinder balance test. Low compression on one of these cylinders rules out the injectors as being the most likely cause of the problem. Look at cylinders that fail the cylinder balance test but have good compression. These cylinders either have a bad injector, bad spark plug or spark plug wire. Move the wire and then the spark plug to another cylinder and run the cylinder balance test again. If it follows the moved wire or spark plug, you have found the problem. If the same cylinder fails the test again, the injector is bad. If different cylinders fail the cylinder balance test, you have ignition problems or wiring problems in the 10 pin black & white electrical connectors located by the EGR.
How to do a compression test:
Only use a compression tester with a screw in adapter for the spark plug hole. The other type leaks too much to get an accurate reading. Your local auto parts store may have a compression tester to rent. If you do mechanic work on your own car on a regular basis, it would be a good tool to add to your collection.
With the engine warmed up, remove all spark plugs and prop the throttle wide open, crank the engine until it the gage reading stops increasing. On a cold engine, it will be hard to tell what's good & what's not. Some of the recent posts have numbers ranging from 140-170 psi. If the compression is low, squirt some oil in the cylinder and do it again – if it comes up, the rings are worn. There should be no more than 10% difference between cylinders. Use a blow down leak test (puts compressed air inside cylinders) on cylinders that have more than 10% difference.
See the link to my site for details on how to build your own blow down type compression tester.
Thanks for the input guys, pulled the codes (none) and did a compression test. As for the injectors, if one was leaking that would be quite noticeable. Everything looked great so I decided to take a little drive. Topped off the tank and drove the 40 miles to my dads house to pick up some tools I had to get anyways. When I got back home with 81 miles on the trip I topped off the tank again and it took 3.8 gallons for a total of 21.3 mpg.
So it seems all is well, just the type of driving she does. All city, short trips, lots of idle time. Even getting ~120 to a tank, shes only filling it up every 2 1/2 weeks so thats really not too bad. Thanks again guys. Just goes to prove that the type of driving you do has a huge effect on your mileage.
I go 5-7 miles of city driving each way to work, and average 190-210 miles per tank. I usually put in 14-14.8 gallons at a time.
The car most likely doesnt even get into closed loop by the time she shuts it off, especially in this colder weather with longer warm-up times.
Probably will change the O2's, they might even be the originals...
