ok guys i have a dss 306..afr 185s afm b-31 cam..38lb inj 80 mm mass 70 mm tb..and a s-trim...as of now in getting about 9-10 lbs of boost...with a 6 rib set up...2.87..up top and 6.00 on the crank......what i want to know is if i want more boost, whats gonna be the best way,,,should i go with an asp 7 inch crank pully (6 rib) and be done. or should i go up to (8 rib).2.95 and 6.87....what would give me the most...your thoughs
