According to the e9zf part of the part number that MAF is for a stock mustang 5.0 with 19lb injectors. A stock MAF can't be tuned. The only way the stock ECU can be tuned is with an external chip that connects into the computer. There are a few different ones....![]()
Without the MAF or chip the car won't run right.
If it ran with 42lb and the computer that's in it then it should run if everything that was in it was put back on.
That's exactly what I'm thinking, only thing difference is I changed to 24# injectors but it still should run ok.
