I am going to be switching an 88 motor to a carb, and I have an 84 donor motor for the swap, but I have never seen what or where exactly the cam eccentric is. As far as I know, I have to use my 84 timing cover, and I have never seen the inside of a carbed timing cover. I know I will have to remove the harmonic balancer for this (do I need a balancer puller/installer, or is there a backyard mechanic way to do this)? Next is, will I have to remove the timing chain/gear, or is the cam eccentric infront of the timing chain, what is the exact process for removing the cam eccentric, or does the 88 motor already have a cam eccentric on it? (I have heard rumors of there already being one on).
