It would depend upon how bad it is.
Remember that in the old days, cars were not so prude with the fuel delivery - all cylinders were being hosed down with extra fuel when not absolutely needed.
You could pull the injector and have a shop check it out, or do your own test (connect regulated air to the injector, set it at 40 PSIG and put the pintle-end into a cup of water with a dash of soap. When the air is flowing, if the injector leaks you'll get bubbles.
Good luck.
