Not anymore. He collected them all together and made this:
Then forgot where he left it.![]()
Who comes up with something like that? Awesome, but so odd all at once, lol.
Noobz has his own orbit.Who comes up with something like that? Awesome, but so odd all at once, lol.
Have you checked your EFI harness ground? It runs from the drivers side EFI harness, comes out near injector 6/7 and runs to back of driver side head. I was missing this ground and I think it's what caused my weak/no spark on my previous white notchback.Who comes up with something like that? Awesome, but so odd all at once, lol.
I had a similar issue that you are having, and I thought it was my computer as well. Question: when you turn the key to the "ON" position does the fuel pump prime?
It ended up being the pick-up coil in the distributor that I just rebuilt (new pick-up coil was cracked) Do you have a spare distributor laying around?
Pull your codes again. You stated that you had an ACT code and ECT code? ECT is probably due to engine being cold but I wonder if the bad act is causing you to be so rich on startup the car won't start.
Have you tried to start it with pedal to the floor?
If have a verified good working A9L that came in my 90' LX 5.0 5spd. It was removed to run the PiMP ECU. I don't mind loaning it. Good luck!
I do not have a spare distributor, but did swap out the pick up with a new motorcraft unit, as well as the TFI module.
So you took apart the distributor and replaced the pick-up coil inside the distributor?
Hey man. If that computer doesnt work maybe i could video chat you through it.
It absolutely sucks to work on something and then have something else goes wrong.
Have you checked the computer griund by the battery ?
There has to be a simple answer to your problem.
