I really appreciate all the advice you guys are giving me. So the key here is just get some time in the seat and don't try and repeat what got me a low 14 second run. Doing that will only get me ANOTHER low 14
All that being said....if you can repeat a 14.2 time after time, and your a bracket racer, leave it alone. In bracket racing consitancty is the holy grail.I really appreciate all the advice you guys are giving me. So the key here is just get some time in the seat and don't try and repeat what got me a low 14 second run. Doing that will only get me ANOTHER low 14
You're a better man than me, and all those I've hung out with at the track. I've yet to see better than a high 1.9 on street radials with near stock Fox at the track... and those were very rare.One should be able to coax sub 2.0 sec 60 foot with stock worn out Goodyear Eagles that the car was born with. Finnese is key. Many a time I have got a near stock 88-93 5.0 to run sub 14's with a 1.8ish 60 foot with stock tires. The key is finding what the car wants. The OP's car will easily go sub 14's if he puts some laps on the car and find what it wants. Doing the same thing over and over again exactly the same teaches you nothing.
Timing is set at 14°..I did notice when I plugged in the spout connector the thing went from 14° to almost 20°..is that normal?I wish I had more time to reply to this thread(have to go to work).
Your trap speed is low for what power you should be making. I have questions there. What is your timing set at? Have you checked codes etc? If it's running fine I suppose you're good there but something seems amiss. I would expect 100-103mph.
For your setup I'd buy some dot legal bias ply tires. I ran 13.8 with completely stock setup with some M&H dot tires. You can launch fairly aggressive without 6k dumps. More like 4500 and slip the clutch aggressive but smooth..and you'll have 13 sec slips all day every day. Also not super hard on trans. The T5 has more of an issue with power shifting than on the launch. I e broken a few and an axle before lol.
All that stuff has been replaced within 1000 milesYeah, the timing is normal, but at your power level, I'd prolly give her a tune up. New plugs, wires, rotor, fuel filter. I don't know what "eve stuff" is, but I'd get a handle on that check engine light before anything.
I shift right around 5500 rpm when I feel it starting to level outThere is a sensor out of range is my guess. Get a code reader and run the codes. There is a sticky on this site that tells you how to do it and how to fix "problems"
I bet this alone might pick you up some mph just in "fixes"
Also on stock tires (if you continue to use at track) don't launch above 2k. Slip the clutch just off of idle and work up until you find the sweet spot.
What rpm do you shift at? Are you using a stock tach? They often are not 100% accurate. What fuel system do you have? I.E. what fuel pump,inj,maf,cai and size of tb. I would start off at 5500rpm shifts and go up and down to find what the car likes. Just keep good records and experiment.
Oh! There is your issue! Your stock tach is definitely going to be off at higher RPM more than it is at lower RPM for you're probably looking at with your timing light. I've never seen a stock tach that was accurate at the top of the power band. Also, I believe that the best way to get a sense of where you should shift is to put the car on the dyno and look. I'd be happy to help you with it if you posted the graphs. You are likely to shift at over 6000 RPM to optimize the combination you listed. I think you're giving up all your mile per hour right there.I shift right around 5500 rpm when I feel it starting to level out
Stock tach yes. But I have a good timing light that reads rpm and the tach is actually very close according to the timing light
