cobra mass air question
95stangGT
513
Buffalo, NY
I'm selling a Pro-M 80mm mass air calibrated for 42 lb injectors and the cobra computer on ebay. Now I got this question from an ebay user and it has me stumped becuase of how the cobra computer works being calibrated for 19s I think but running 24s. I got a gt which is why I can't use the meter so have no clue about the setup. Can anyone exxplain it to me so I can give him an answer. Here is his question. Thanks :nice:
i have a 95 cobra with a vortech sc, i run 36 pound inj. with a pro
m 80 mm. calibrated for #30 inj. running a fmu. do you think going with
your meter and purchasing #42 inj. is a much better setup. and if i'm
correct your meter should be calibrated for #36 inj. if you were
running a stock computer. let me know what you
think...................thanks
95stangGT said:
Pro-M knows its suppose to be used on a cobra. I got the meter with my turbo kit. so knowing this, should this meter be used on a cobra with 42lb injectors?
YES is the answer I believe would be correct because...............................
If I understand correctly, he is going to be using the maf for the same application as you had originally planned to do. If that is the case, then all should be OK.
Here is a bit of basic info on ProM's cheat calibration method.
Grady
