I bought this stang from a friend of a friend and hes said that he had the motor rebuilt but he didnt install it because he got shiped off to Korea before he couldinstall it. I put the motor in the car and it has never ran like it was suppost to.I tried everything and my friend did a compression check on it and it showed like 55-60 on 2 cyl(i dont know which ones). Iv heard of people having a hard time getting the rings to seal after a motor rebuild.Does this sound like what it is?Any good waya to get them to seal or should I just tear it down?Thanks for any help.
.But if there just improperley adjusted then Ill just adjust them and be happy for now.The only kind of test that Ive done to check wether or not its the valves or rings is when I was messin with the intake I ran the car with out the PCV or the tranny vacum line but plug the holes on the carb and I got blow by and smoke.Would it do that casue the PCV was just not hooked up.The blow by want real bad but I could hold my hand over the oil fill hole and let it up after a few seconds and hear a hiss like air was excaping.Any ideas.Im going up there this morning to try and figure something out.
