Converting to manual steering ?'s HELP!!!
  • Thread starter Thread starter mustangman70
  • Start date Start date Jul 24, 2004
M
mustangman70
1,235
St pete, Florida
Jul 24, 2004
  • Jul 24, 2004
My steering allways leaks, the cylinder rod (ya know the one that is connected to that bracket to the frame SNAPPED off the other few months ago and is hanging down, I took out my A/C becasue i never use it, and The stang is becomeing a weekend warrior pretty soon anyways, and im just plain sick of its problems, what is involved in converting to manual? any one have a step by step process>?
PLUS REAL motors only have one belt lol BTW i allready know how to change the front of the motor (pully and such)
R
Ronstang
1,294
Houston Texas
Jul 24, 2004
  • Jul 24, 2004
Get a manual centerlink and just delete all the power stuff and you are good to go. You can use your old tie rod ends. I am only real familiar with the 65-66 cars and on those even though the driver's side tie rods are different for power cars they will still work....or you can replace them with manual ones if you like. This may also be true on 67-70 cars but I am not completely sure.
6cougar8
246
  • Jul 24, 2004
You may have to get a different idler and pitman arm. Not sure but I believe the pitman arm for p/s has a hole for the centerlink, where the one for manual has the stud to go into the centerlink. Think the same is true for the idler arm.
LMan
1,246
Mom's basement
Jul 24, 2004
  • Jul 24, 2004
Manual centerlink, pitman arm.
65fastback2+2
1,229
Louisville, KY
Jul 24, 2004
  • Jul 24, 2004
question, why not rip the cylinder ram and pump and belts and hoses off???? why does it matter if the center link has the control valve on it or not?
blown65
1,938
Queen Creek Arizona
Jul 24, 2004
  • Jul 24, 2004
lmao, my car has been a manual car for 13 yrs now. Well it was a power assist but I yanked the crap off and never converted it. I dont think I ever will. Maybe it would turn a little easier, but I'm not a girlie man so I just put some arm into it.
burnout289
1,000
sun diego
Jul 24, 2004
  • Jul 24, 2004
i got a kit from i think Canadian Mustang a few years ago. rip all the crap out and the kit caps off the valve. i would like to get rid of the parts, too.
M
mustangman70
1,235
St pete, Florida
Jul 25, 2004
  • Jul 25, 2004
damn double post, read below
M
mustangman70
1,235
St pete, Florida
Jul 25, 2004
  • Jul 25, 2004
Ill post the link to the part i want to buy, it gets rid fo the "power cylender".....its hard to explain but just go to the link. and that the only piece i will need. http://store.cal-mustang.com/cm_able/showdetl.cfm?&DID=7&Product_ID=3133&CATID=19&CM_SA=0
Its not that simple 65fastback2+2....See my P/S pump shares the water pumps belt, SO i will have to use my 66 alternator brackets (block is out of a 66) throw the C/S pully i pulled off (which is one groove) and use the old alternator belt. Liek i stated above i know how to do the rest lol, ill let ya guys know how the install goes.
uuummm hey blown..........i just read your sig.... WTF hapend man!!!
65fsbkhipo
1,296
Tampa, FL
Jul 25, 2004
#10
  • Jul 25, 2004
  • #10
mustangman70 said:
Ill post the link to the part i want to buy, it gets rid fo the "power cylender".....its hard to explain but just go to the link. and that the only piece i will need. http://store.cal-mustang.com/cm_able/showdetl.cfm?&DID=7&Product_ID=3133&CATID=19&CM_SA=0/QUOTE]
Take a look at this one...Manual Steering Adapter
JimBowy
330
Downriver, Mi
Jul 25, 2004
#11
  • Jul 25, 2004
  • #11
burnout289
1,000
sun diego
Jul 25, 2004
#12
  • Jul 25, 2004
  • #12
http://www.americanpony.com/store/store.mv?Screen=PROD&Store_Code=SF&Product_Code=MagAd15-1
this is what i got. you don't have to take the valve off, just gut it and plug it. half the price, too.
edit: i love the banana.
page62
63
San Antonio, Texas
Jul 25, 2004
#13
  • Jul 25, 2004
  • #13
I spent a few more bucks and got the assembled unit:
http://www.americanpony.com/store.mv?p=700208
Now that my shock towers have been repaired and pulled apart -- plus a decent alignment from a shop that cared to do a good job -- the car goes down the road straight with no wander, and steering effort is very light.
Unless you parallel park 10 times a day, dump the power steering junk and do it!
6cougar8
246
#14
  • Jul 25, 2004
  • #14
You can remove certain components of the original valve and weld the end of it shut (once it is adjusted) then put it back on the car. Just remember how it was orientated before removing it.
Only thing about doing it this way is that you will still have a bit more slop in the steering then if you just convert it over using the manual parts. But, that's just me.
70XR7ConvertCat
Livermore, California
Jul 25, 2004
#15
  • Jul 25, 2004
  • #15
I hope that kit captures the ball stud in the control valve. If not, the valve will still actuate from side to side, and you'll have slop in the steering. I'd go with the manual adapter, but that's just me. If your control valve works at all, you may be able to sell it and recoup some of the cost.
Steve C.
burnout289
1,000
sun diego
Jul 26, 2004
#16
  • Jul 26, 2004
  • #16
comes with parts that get stuffed inside the control valve. but yeah, if you want to sell the unit, you'll want a kit that removes everything. but if you are going that route, wouldn't it be cheaper to get a manual centerlink & pitman arm that the $150 adapter?
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Wednesday at 4:28 AM
2v_johnny
M
  • mnky99
  • Sep 5, 2025
mnky99
M
For Sale 3-owner 1987 Mustang GT, $18K obro, Lancaster CA
  • Bill Cool
  • Oct 6, 2024
2K
Fox Body Mustangs For Sale (1979-93) Oct 13, 2024
nickyb
Convertible Top Replacement SN95/NewEdge
  • MineralMan
  • Feb 15, 2023
7K
1996 - 2004 SN95 Mustang -General/Talk- Jul 1, 2024
old fella 2
O
'88 GT Convertible - Croatia, Europe
  • snovak
  • Oct 9, 2020
  • 23 24 25
49K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 12, 2025
snovak
