Diablo Predator Arrived Today!!!!!!!
01mgvert
302
After a two month wait, I received my Diablo Predator from rpmoutlet ($399). In two minutes it stored my stock tune, and in another two minutes it installed a Diablo tune (advanced timing and optimized air/fuel ratio), including a re-calibration of my speedometer for 4.10 gears.
There are additional parameters that can be adjusted but I'm not sure what to do. For example, you can make dual timing and dual fuel adjustments (for this, you probably need an a/f monitor), you can change the speed and rev limiters, and you can modify shift pressure, shift points, and torque modulation. You can also turn off the traction control and adjust the cooling fan temperatures. The Predator also has diagnostic capabilities; it can scan and erase fault codes and monitor live data while driving.
Any suggestions on adjustments to these additional parameters?
Also, what kind of horsepower was gained with this tune?
Awesome! Ive been leaning towards superchips or hypertech programmers, but the diablo sounds better. Do you have a auto trans. It only took 5 mins to swap programs, thats good. Can advance the timing 14 degrees like with the timing adjuster?
I'm not sure where the timing is on the Diablo tune. I've heard from others that 14 degrees is the best.
Interestingly, my car had half a tank of regular gas yet it did not ping with the Diablo tune. Do I really need premium gas? Or should I attempt to make additional adjustments to the timing?
just because you can't hear it doesn't mean it's not happening ;) if it were me, i would rather be safe than sorry
DELOS02GT said:
Did you notice any gains with it? I have mine on order...I hope it will be here next week. I ordered mine like 3 months ago....I can't take waiting anymore!!!
I noticed a SOTP gain? Comparable to the gain I felt from adding the Accufab 75 mm throttle body and plenum. I was expecting (hoping for) more. Perhaps after I play with it for awhile, I can squeeze out a few more ponies.
el_kid_1 said:
What parameters can you datalog with the Predator?
The live data parameters are divided into larger categories: ignition contol, speed contol, trans control, and fuel control. Beneath each category is a list of acronyms with corresponding definitions. If you go to diablosport.com, you can download the instruction manual for the Predator.
