  • 1994 - 1995 Specific Tech
disappointing day
  • Thread starter Thread starter 95stangGT
  • Start date Start date Oct 13, 2004
9
95stangGT
513
Buffalo, NY
Oct 13, 2004
  • Oct 13, 2004
Well my car finally got lowered off of jack stands for the first time in a year. Setup is PTK street kit w/ a T67, ASP underdrive pullies, 42 lb injectors, 255 in tank, Pro-M 80 mm calibrated for 42 lb injectors but for a cobra comp and I have a GT. We set the timing with the spout out to 7 degrees also. Now while on jack stands earlier today it idled fine and revved nicely. As soon as I tossed the wheels on and tried to pull out, it ran extremely rich and spuddered dieing out. When we pushed it outside I started it back up becuase it instantly filled our garage with smoke. When I started it outside it got a miss in it. Is it possible that the miss is from soooo much fuel in the combustion chamber. It spudders pretty far up RPM wise and never really clears out. Any points on what's happening and where I should go from here. Thanks
Numbles
998
Chicago, IL
Oct 13, 2004
  • Oct 13, 2004
First Id check the firing order and clean the MAF.
Im not too good at diagnosing problems like this but TTT for ya.
Killercanary
The car that set the bar.
Altoona, PA
Oct 13, 2004
  • Oct 13, 2004
The problem could be that only have 7* initial, AND TOTAL if you didn't put the spout back in, if you did put it in then this shouldn't be the problem.
Did you disconnect the battery? If so, I'd either disconnect it again, or try to start it and let it just sit and idle for at least 3-4 minutes. Give the O2's some time to realize you just added a butt load more fuel to it and try to compensate. Do you have any type of tuning devise? If not you may have to get one and have the pulsewdith at idle trimmed way back to avoid an excessively righ condition. If the plugs are fouled, it will miss like you describe. Hope it turns out to be something minor as that should be a KILLER setup when its tuned and running right. Good luck.
Killercanary
Altoona, PA
Oct 13, 2004
  • Oct 13, 2004
BTW- what's your plug gap set at? It should be around 40 thousandths to avoid spark blow out. This shouldn't be a problem at idle or it your not into boost.
94TURBO5 O
2,509
VA
Oct 13, 2004
  • Oct 13, 2004
Big mods always have bugs my friend, but when they get worked out you'll feel some serious hp. That's the thing with taking them apart they never run the same so you gotta just tweak around, the power is in there you just have to extract it out patiently.. I'd do what Paul said for a start and let us know what happens after that.
9
95stangGT
513
Buffalo, NY
Oct 13, 2004
  • Oct 13, 2004
Here's the kicker. When we first set the timing we forgot to put the spout in and it was running nicely. Then when I realized the spout was out I plugged it in and the car died like 5 seconds later.
The battery is constantly being disconnected so thats not it and the car is given enough time for the O2s to adjust.
Plug gap is at .035
9
95stangGT
513
Buffalo, NY
Oct 13, 2004
  • Oct 13, 2004
Maybe a tweecer R/T should be next on my list becuase I would really like to get it to run good before adding more mods.
Already got a systemax II intake going on this winter when I do a fox throttle body swap
94TURBO5 O
2,509
VA
Oct 13, 2004
  • Oct 13, 2004
How are your HG's? Where the heads off?
DougNuts
2,596
Georgetown Ky
Oct 13, 2004
  • Oct 13, 2004
Is that the problem? Don't the cobra computers have 24# injectors in the program. That would mean the MAF's transfer function (is that what it's called) would be off by a little.
ex. 19/42 does not equal 24/42
The other idea I had is a vacuum leak of some sort.....
Edit: Am I the only one who feels like they've forgot more mustang info than most people know?
9
95stangGT
513
Buffalo, NY
Oct 13, 2004
#10
  • Oct 13, 2004
  • #10
Heads were never off. Car never even had the chance to create boost to pop one either
HoofnIt
1,175
North Carolina
Oct 14, 2004
#11
  • Oct 14, 2004
  • #11
The cobra computer is different with respect to the injector size. If you still have your GT computer then why not swap it in and see if it makes a difference?
VibrantRedGT
"STANGNET'S PENGUIN SMACKER"
424
154
Boca Raton, Florida
Oct 14, 2004
#12
  • Oct 14, 2004
  • #12
You trying to run 42# injectors straight up? There is no way in hell the car is going to run right with 42's and a stock EEC. My car ran so rich it would shoot 10 foot streams of fuel out the tailpipes. With an injector that large you will have to use a tuning device to change things around a bit. The miss is probably due to fuel trying to foul the plugs out. Been there and done that.
9
95stangGT
513
Buffalo, NY
Oct 14, 2004
#13
  • Oct 14, 2004
  • #13
I don't think with the way its loading up that would make the big difference
9
95stangGT
513
Buffalo, NY
Oct 14, 2004
#14
  • Oct 14, 2004
  • #14
So what your saying is that without a chip I'm screwed. lol
SorsCode
20+ Year Stangneter
Jun 10, 2003
1,024
434
113
St. Louis, MO
Oct 14, 2004
#15
  • Oct 14, 2004
  • #15
I replied to this post on the Corral and BTW i ran 42lbs with stock EEC with problem.
DougNuts
2,596
Georgetown Ky
Oct 14, 2004
#16
  • Oct 14, 2004
  • #16
Why not? Ever hear what happens when people drop 24# injectors on a GT and don't change the MAF? Runs pretty rich from what I've been told.......
Now, multiply that by the fact that you have huge ass injectors and a small change in pulsewidth means you're roasting marshmellows. I'm not saying I'm right here, but it's something I would look into a bit more.
Like I said above, I've forgotten all of the GT/Cobra computer/MAF differences so I may be talking out my ass. But, if there is a difference in a MAF calibrated for 42#ers and Cobra computer and one calibrated for GT computer, I would wonder if that's the problem. Also, are you getting any check engine lights?
F
fastf50rd
720
mass.
Oct 14, 2004
#17
  • Oct 14, 2004
  • #17
Without a doubt, you need some sort of chip or eec tuner. My s/c only made six pounds of boost, with the 42's just ran like complete junk without my chip. It'll always be way too rich, on the dyno my a/f ratio was way off the scale which stopped at 10:1 at WOT. I didn't even get it tuned on the dyno, I just got a mail order JMS chip and everything was well. A good investment for $325, dyno time is too damn expensive at all the local shops.
9
95stangGT
513
Buffalo, NY
Oct 14, 2004
#18
  • Oct 14, 2004
  • #18
UPDATE
Well here's alittle update for today. She lives! lol
Like a few people suggested I played around with the mass air. Started it up and it ran descent. So decided to see if she'll be able to move this time and I had no problem backing her up. Then drove around the large parking lot. You can tell she's alittle rich but other than that ALOT better. The road our garage we rent is on is pretty long and straight. So I waited till it was alittle dusk and pulled it out again. Waited till I saw no headlights in either direction and gave it alittle rip. I gave it like half throttle, heard the turbo spool and suddenly I was pushed back into my seat. What an awesome feeling. Not to mention that bad boy is loud Was running open y-pipe and had no problem hearing it. lol At least now I know tuning won't be so bad once I get the right calibration and stuff. So thanks to all for the suggestions
VibrantRedGT
424
154
Boca Raton, Florida
Oct 15, 2004
#19
  • Oct 15, 2004
  • #19
Not a good idea to rip on a power adder car without a tune. I learned the hard way by changing head gaskets just a few days after the blower install. Do yourself a favor and head over to a dyno ASAP. JR can also atest to this.
9
95stangGT
513
Buffalo, NY
Oct 15, 2004
#20
  • Oct 15, 2004
  • #20
I'm not really ripping on it. Just making sure if I go through the trouble of trailoring the car to the dyno, that it will actually run and not totally bog down or something. Only going to the dyno to get some #s and a W/D O2 done. Then getting a tweecer R/T this winter.
L
Help with 1986 GT 5 Speed Please
  • Lcasada1999
  • Mar 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
11K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
C
Engine Oil pressure issue
  • Cg’s 347
  • Jan 15, 2024
4K
Fox 5.0 Mustang Tech Mar 2, 2024
AeroCoupe
Progress Thread Giving an abandoned 88 GT project a new chance at life
  • jaketractor
  • Jan 9, 2025
2K
Fox 5.0 Mustang Tech Jul 20, 2025
New daily driver help needed.....not a mustang but mustang drivetrain.
  • Wayne Waldrep
  • Jun 17, 2024
  • Other Auto Tech
  • 3 4 5
7K
Other Auto Tech Jul 28, 2024
manicmechanic007
