Do rear end gears add to your HP #'s on a Dyno?
higher numerically gears will lower your rwhp #'s....you're spinning everything faster which consumes more hp.
Lots of cars don't have a 1:1 ratio gear...smart car manufacturers provide gear ratios suited to the engine performance to give best results...not like ford that puts a 1:1 4th and a stupid high 5th.
/thread
I was thinking that the M6 in the vettes and F bodies had a 4th that was like 1.1 instead of a 1.0, but I may be wrong. I knew that a 4.10 gear would show a lower # on the dyno LOL, glad 300 came in and said that...although I still dont fully understand the reason LOL...just the basic reason.
If the dyno is calibrated correctly the gears shouldn't lower it. When you do the other gears the reason is that it is supposed to be a "torque multiplier" when you have lower gears there is less load. 1:1 ratio is used because any multiple of one will be the same so it gets you an accurate reading. Now gears do not add torque what they do is help you reach your powerband faster and hit your peaks they will not affect numbers. They can affect your torque numbers if the dyno doesn't know what they are doing though.
300bhp/ton said:
WOW, and not whishing to upset anyone BUT WHAT A LOAD OF CRAP RESPONSES. (obviously not all of them but most of them :rlaugh: :shrug: )
Its almost embarrising being a member of this board with some of these dumn ass posts.
While this part was essentially uncalled for, to the rest of the post I wholeheartedly agree. It can be boiled down to this:
wheelHP = (wheelRPM x wheelTorque) / 5252
wheelRPM varies inversely with final gear ratio, wheelTorque varies as the final gear does making gears a mathematical wash in the equation to calculate power.
If you change from 3.27s to 4.10, yes, you do indeed apply something like 25% more torque to the hubs. However, for any given engine RPM, the hubs are also spinning 25% more slowly. So while wheelTorque goes up by 25%, wheelRPM goes down by 25%...1/0.25 * 0.25/1 = 1.0... The power delivered to the hubs doesn't change, in theory.
As 300hp/ton notes, the changes are probably more due to changes in setups (e.g. backlash, bearing preloads etc), oil viscosity differences, wear/break-in differences and so on than to any other factors.
IN SHORT DON'T WORRY ABOUT IT, IF YOU DYNO LOWER NUMBERS WITH 4.10'S JUST PUT IT DOWN TO THE PHYSICS AND BE REASURRED THAT YOUR ENGINE IS STILL PRODUCING THE SAME POWER. AND IN TERMS OF ACCELARATION YOUR CAR WILL NOW BE FASTER.
To this part I will agree to an extent but will offer that the effect is largely illusory. While the instantaneous acceleration might be greater, the net speed acheived are less, again meaning a wash. Lower ratio gears typically better a street car's "squirtability" by allowing the engine to be higher in the RPM range at any given speed and, while giving less ultimate vehicle speed, the increased mechanical advantage gives quicker instantaneous acceleration. They feel better. At the strip, gears can help dig a car out of the hole, launch at a given RPM on slicks and not bog out of the hole and so on. One typically sees the benefits in reduced 60-foots (and the attendant improvement in ET) but not much in trap speeds, the true measure of power making it to the wheels.
But without more power, your car will not be "faster". It may seem like it, but it won't be.
An engine makes X amount of BHP, if this is measured at the wheels there will be a loss due to the power required to turn the drive train, differnt lubicants/oils or worn out bearings and components will all affect the amount of friction and the amount of loss. Also the tyres will affect the results right down to the tread pattern, pressures and balance as well as size and weight of them.
Then you have atmospheric factors, altitude, temp, humidity and so on.
And then all the different rating systems (there are 10 or so different ratings of power BHP, SAE, Net, Gross, HP, PS, KW) with different correction calculations which can be used. The variance between even the HP readings could be 10hp +-.
Then there is whether the dyno is actually calibrated correctly, and whether any of the correction calculations are used and how accuratly they are.
In short ANY rolling road dyno is inaccurate to start with. This is an import fact to understand in relation to getting readings from them.
Your car may well dyno 250rwhp and a friend might only get a reading of 220rwhp but they live a 1000 miles away (hence different dyno and test conditions), there is every chance that even though they have lower numbers their car is more powerful than yous - EXCEPT IT, because its true.
No matter what gear you are in the engine WILL ALWAYS produce the same power with the same profile (look at the dyno graph), the profile of how the power is delivered is much more important than the PEAK nummbers!!!!!!
To get a rwhp reading the dyno must induce load onto the engine, but becuase you have a gearbox which is designed to reduce load thru gearing (less effort (easier to turn) but more work (more revolutions)), the readings can become even more inaccurate.
What you need to do is select the gear that has the closest (as not all car will have one, hence comparing rwhp from different makes of cars is pointless) ratio of 1:1. One turn of the gear is equal to one turn of the propshaft. This way the load is not being increased/reduced by gearing.
So in essence a lower gear (such as 1st or 2nd) is reducing the load on the engine, which makes it easier to turn the wheels. A higher gear such as 5th maybe a ratio of less than 1 to 1 (0.x:1) will mean more effort is required to rotate the wheels with load on them. Hence a car will accelarate from 1200rpm in 1st gear faster than it will at 1200rpm in top gear.
The final drive ratio (often referred to as 'gears', such as 4.10's 3.73's) will have no bearing on this at all, as it is after the gearbox in the drive line. What it does do is have a bearing on how many rotions the propshaft makes to rotate the wheels.
So what does this mean on the dyno?
Well no matter what is done to the drive line it will have no affect what so ever on the power of the engine. So having 4.10's will not affect the amount of bhp you have. However it may dyno a different number because of many reasons, such as:
-Fresh oil and components causing a lsight reduction in firction loss through the crown wheel and pinion.
-Lower rotaing mass, if steel parts are replaced with aluminium they weigh less and require less effort to rotate them.
-And due to the gearing ratio change of propshaft rotations in relation to wheel rotaions.
All in all the change of final dirve ratio should affect the dyno numbers, but only because it is polluting already INACCURATE numbers.
It should be noted that dyno's do record accuratly, but it is not How they record it but WHAT they record. As the information (ie the hp & torque numbers) are polluted and inaccurate to begin with.
A change of final drive ratio should alter the accelaration of the car, and make it appear to have more/less power depending on which gears you went for. A numerically higher gear (4.10) is making it easier for the engine to turn the wheels, the ofset is that the wheels have to spin faster to maintain the same speed, hence you may have to be a gear higher than before to reach a particular speed. This process is finite however as if you increase the gears too much you will have a very limited low top speed in each gear, and the engine will be over revving and not being able to make use of the power it is generating.
A numerically lower gear should reduce engine rpms at set speeds, but it requires more effort to accelarate to that point, hence accelaration is slower. By going this route you should be able to theorestically increase the potential top speed, the downside is that as the gearing is higher it will require more power to acheive the same speeds, so in most cases the top speed remains constant unless a mssive power increase is also achieved.
:stupid: too many people on this board care about dyno numbers. the dyno is a tool that is usefull too tune a car. who cares about peak numbers. there are just too many factors into why your buddy jimbob's 01 gt put down 244 stock and you put down 240..
Lots of useless arguing here. The question was- 'Do rear end gears add HP on the dyno?'. Not 'do gears make cars faster, or effect engine performance'.
No, gears reduce your numbers on a dyno.
Here my automatic car was dynoed in 3rd (1:1) , and then in 2nd (1.55:1). The 2nd gear numbers are a lot lower due to the higher gear multiplication. This is comparable to properly dynoing a car with 3.27s, then with 4.10s. You'd see similar, less dramatic results.
Now to answer the question of the topic, steeper gears reduce rwhp/rwtq readings. They do NOT change the amount of power hitting the ground, only how it is read.
attachment.php
