Stang|ess said:It is when you throw it in neutral, rev match for the next gear or let the rpms fall for an upshift, then press the clutch in and put it in gear. Hence the term, double clutching. It's a rather slow process not to mention useless with modern technology.
Yeah Vin Diesel mislead a lot of people. Do actors even know or read scripts?Crzyhrse said:(Vin Diesel voice) "Granny shiftin' instead of double clutching like your 'spose too".![]()
blackink00 said:my tko-600 shifts smooth as butter. although 3rd and 5th gear is a little loud
?LB0193 said:Got to double clutch the old Model A.......she moves out......
Must have crazy torque to blow the rear!(J/K) must be cool to see one in person.LB0193 said:Just a joke the old old cars had to be double clutched...and were very slow my stepdad has a model A thing tops out at 50mph......he tried to do a burnout once in it and blew up the whole rearend........
(stock 3.27 gears). That one will really put you in your seat. Also, it makes downshifting a lot smoother. When you are proficient in double clutching you can take it a step further with heel-toeing too. Where you hit the gas pedal (in neutral) while you are on the brake headed into a turn. It takes a lot of practice, but when you get good at it, it's a lot of fun. Give it a try, but not in traffic...
