Drive line shake.
  • Thread starter Thread starter 91badazzgt
  • Start date Start date Nov 10, 2008
9
91badazzgt
  • Nov 10, 2008
Hey im new to stang net. Ok i have a 91 gt with a 302 bored to a 306. has 1.6 fr roller rockers,edelbrock rpm2 intake man,bbk70mm throttle body,msd wires,g force racing t-5, aftermarket clutch.And if your sitting in neutral, and rev it to like 2500 and hold it itll have a drive line shake. it didnt always do this. it was there and went away for a while. then i missed 2nd and it reved high and now its there again. Im think harmonic balancer. The block is a 1970 era block converted to roller cam ect..... can anyone help. im thinking that or a flywheel. can anyone help me out?
hotcobra03
poteet,tx
Nov 10, 2008
  • Nov 10, 2008
What happens if you put car in gear and 2500rpms?
9
91badazzgt
  • Nov 10, 2008
when i put the car in gear( driving car) it'll start vibrating more furious the higher the rpms go.
97gsr
31
  • Nov 10, 2008
i have the same problem still have not fiugured it out i am thinking possible balance.
hotcobra03
poteet,tx
Nov 10, 2008
  • Nov 10, 2008
While sitting in neutral not touching clutch trans is spinning.in gear clutch pushed down trans stops spining.that will tell were to go next
EMW150
2,020
Roaring Spring,PA
Nov 11, 2008
  • Nov 11, 2008
Since it's been intermittant, that throws out a component problem. When you said 70 block I was thinking someone probably installed the wrong balance flywheel and balancer since pre-82 were 28.8 imbalance. Chances are it's the balancer or it could be a clutch problem.
hotcobra03
poteet,tx
Nov 11, 2008
  • Nov 11, 2008
Any thing that spins can viberate.its hard to find when not on wheels or shaft.when you are still motor clutch and input shaft thru trans .when in gear trans stops than only motor and clutch spin.if vib is gone when in gear than trans is the cause.if still thier.vib in eng are 1 outa 100.clutch vib are 99 outa 100
7upstang91
936
124
74
Florida
Nov 12, 2008
  • Nov 12, 2008
most likely the harmonic balancer. or get the drive shaft for any serious dents that will cause the same thing.
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
12K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
LESS THAN 9.5 MPG CITY DRIVING!!!
  • PonyGTrider
  • Dec 15, 2022
  • 3 4 5
12K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 6, 2023
PonyGTrider
A
1991 5.0 with HCI - started car, running for a few minutes, started pushing coolant into the overflow tank and then puking out from there. I'm lost
  • AmericanMuscle4.6GT
  • Oct 16, 2022
4K
Fox 5.0 Mustang Tech Nov 30, 2022
CAMTWO1070
Drivetrain Crazy vibration: need some help!
  • 91GTstroked
  • Jul 16, 2019
2K
Fox 5.0 Mustang Tech Apr 7, 2020
91GTstroked
