Dumping Fuel?
  • Thread starter Thread starter Black Sun 5.0
  • Start date Start date Oct 3, 2008
Black Sun 5.0
1,337
L.I., N.Y.
Oct 3, 2008
  • Oct 3, 2008
So I have the beast back on the road. It's been two years. Anyway, I have a bit of heavy exhaust coming out. Not heavy smoke, light smoke, but it smells a lot like fuel. New plugs, wires, sensors, etc. What else can cause this? FYI: no cats.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 3, 2008
  • Oct 3, 2008
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
There is a single dark brown connector with a black/orange wire. It is the 12 volt power to the under the hood light. Do not jumper it to the computer test connector. If you do, you will damage the computer.
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see EQUUS DIGITAL FORD CODE READER (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
Black Sun 5.0
1,337
L.I., N.Y.
Oct 3, 2008
  • Oct 3, 2008
I actually had codes run when the car was in the shop, and a variety of sensors were replaced. I can re-run them myself, I guess, jsut to double check. I have a code scanner at home. But man, I stunk of exhaust fumes all night after my joy ride.
Prime Lord
Crappy Default Title
2,137
199
114
Denver-ish
Oct 9, 2008
  • Oct 9, 2008
what kind of mileage are you getting? Mine just SMELLS like raw fuel if I'm sitting still...and I'm only getting 13ish MPG.
Black Sun 5.0
1,337
L.I., N.Y.
Oct 9, 2008
  • Oct 9, 2008
I'm not sure about mileage yet at this point, I haven't had the car on the road long enough to keep track.
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
Engine Fuel not pumping
  • Creomod
  • Apr 13, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 22, 2026
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
Fuel 93 5.0 fuel problem
  • bjohnson6519
  • Apr 27, 2025
  • 4 5 6
4K
Fox 5.0 Mustang Tech Jul 14, 2025
General karthief
