Dumping Fuel?
Black Sun 5.0
1,337
L.I., N.Y.
So I have the beast back on the road. It's been two years. Anyway, I have a bit of heavy exhaust coming out. Not heavy smoke, light smoke, but it smells a lot like fuel. New plugs, wires, sensors, etc. What else can cause this? FYI: no cats.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
attachment.php
attachment.php
There is a single dark brown connector with a black/orange wire. It is the 12 volt power to the under the hood light. Do not jumper it to the computer test connector. If you do, you will damage the computer.
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Alternate methods:
Or for a nicer scanner see EQUUS DIGITAL FORD CODE READER (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
I actually had codes run when the car was in the shop, and a variety of sensors were replaced. I can re-run them myself, I guess, jsut to double check. I have a code scanner at home. But man, I stunk of exhaust fumes all night after my joy ride.
