thehueypilot
cola8d8 said:They are the stock AFR valve springs, maybe I need to change those....
I dont remember what rockers they are but they were blue.
Dark Night, do you think the stock AFR valve springs with that cam might be what is causing the low power and flat power curve? It is kind of a lot of work to change them but could get me on the right track.
My AFR heads came standard with solid roller cam springs (210#'s) so if you are running a hyd roller the seat pressure is way too much. It cost me extra to have them change them to a 120 lbs seat pressure springs for my AFR 225's. Your hyd lifters could be collapsing because of the higher spring pressure.
