Resolved Electrical mayhem
  • Thread starter Thread starter 2000ElectricGreen
  • Start date Start date Mar 13, 2026
  • Tags Tags
    2000 2000 3.8l mustang evap headlights instrument cluster moisture new edge tail lights water water leak
2000ElectricGreen
Nanaimo, British Columbia, Canada
Mar 13, 2026
  • Mar 13, 2026
I'll write this out as properly as I can, I'm suffering some electrical issues on a car I'm trying to "rescue".
2000 3.8L V6 Base Model, 180,000 km.
I've already fixed the misfires it had and got the engine running quite nicely, no CEL or anything.
Complaint:
  1. Windshield wipers (VERY SELDOMLY) activate without user input / touching the multi-function switch.
  2. Water leaks into the passenger side floor, front, and back. Drivers side remains dry.
  3. Water leaks into the trunk. (found the leaks, figured this out, but it's relevant to my issue)
  4. No tail lights, instrument cluster lights, headlights, signals, etc.
  5. Gas tank pressure is not being relieved, unable to be easily filled due to triggering the anti-overfill.
Intervention / Solutions:
  1. Trunk wiring harness shorted to ground, wires rubbed on the metal of the trunk, melted all wires from the first/rear-most connector to the license plate lamps.
    1. Cut all connectors, remade a harness myself, seems to work perfect. Not sure if this could cause the tail lights to not signal on, seems unlikely upon discovery of corroded headlight switch.
      1. This did not fix the evap / gas tank issue.
      2. Headlights, signal lights, brake lights, all function now, However,
      3. Tail lights and dash lights do not come on when turning on the headlights
      4. Found corrosion leading from the B1 Pin on the headlight switch (Battery Power to Main Light) down into the switch.
  2. Silicone and JB weld for leaks in the trunk-- however, unable to find the leak in the passenger side dash area-- or wherever it's leaking into the carpet. Passenger seats, both rear and front, remain dry (I think that might mean it's not moving down the trunk into the passenger side interior?)
  3. Found stereo wiring under spare wheel, in wheel well, bathing in water. Cut ends, insulated, however hasn't seemed to contribute to any issues besides maybe a parasitic draw.
If anyone has any tips or clues, PLEEEEEEEEEEEEASE let me know. I understand this is a cheap car and that it's not really "worth fixing" However it has great sentiment to me, and the experience of fixing it is well worth the time and cost, so junking / giving up is not an option for me.
What are the odds my GEM is malfunctioning? Just ordered a headlight switch, will update.
Took it out and inspected it, found corrosion from the main power pin leading down inside the switch, and around the axle which the dimmer knob rotates.
squeak93
2,357
419
164
Joplin, Missouri
Mar 23, 2026
  • Mar 23, 2026
#1 sounds like a malfunctioning multifunction switch.
#2 Check heater core drain on firewall - pass side below heater core. If clogged you will get water in floor. -sometimes will still get water in floor - these cars are getting older
#3 sounds like you have that under control
#4 Check fuses, grounds etc. All those are somewhat related. Do you have brake lights or is it all dead? - edit read your notes (You should keep numbering the same its confusing lol). What did you do about corrosion?
#5 Evap cannister unless I'm not understanding what you're trying to relay here.
Reactions: 2000ElectricGreen
2000ElectricGreen
Mar 24, 2026
  • Mar 24, 2026
My apologies, I was rather stumped and irritated when I wrote this, as I had just spent a dozen hours working on it to no victory.
In order:
#1: noted, will try to test and confirm. Never had issues with one of these so I was worried it was a bad relay or gem
2:
I haven’t seen any water draining from the heater core, and seeing as you brought it up, I fiddled a zip tie in the drain and then blasted a very light amount of compressed air into it. However, no water came out. It’s going to rain this week so we will find out in a day or two if that fixed it.
4:
I checked all my fuses and they’re all good, all have continuity. I rewired that trunk harness and now it is as follows:
Brake lights work
Signal lights work
Reverse lights work
- tail lights do not come on when headlights on, however brake signal reverse still work.
So I replaced the head light switch, corrosion seemed bad and I don’t think these are easy enough to repair to justify the 25$ cost.
headlight switch changed nothing,
I still lack instrument cluster lights and tail lights when headlights on,
When headlight switch is set to marker lamps/2nd notch (inbetween off and on), nothing happens with my lights.
I pulled the cluster, looked for issues- and couldn’t spot any.
I’m really frickin lost here. I must have an open circuit or something????
About to google if license plate lamps are parallel or daisy chained, as I just found the socket is corroded.
5: going to just back burner this one. Fixing the trunk harness relieved the issue slightly, as I suspect the purge valve wasn’t getting power and was stuck shut. Still happens, but at this point it’s the least of my worries.
I appreciate your help, I will update after testing multifunction and weather testing heater core drain!
2000ElectricGreen
Sep 4, 2026
  • Sep 4, 2026
quite a while later... and huzzah!
Turns out, previous owner had installed an after market radio system + sub woofers. Unfortunately, they did not put any extra insulation on the wires. No wire sheathing or even electrical tape. Pulled the whole interior, radio, cd player, instrument cluster, headlight switch.
Found the wires that route under the drivers seat towards the trunk. Under the panel next to the seatbelt, multiple wires had shorted to ground, melting nearly all of them.
Replaced fuses, still nothing.
The reason this confused me for so long, was due to the fact that my headlamps fuse, under the hood, had continuity from the visible top anode / cathode. I was measuring continuity but not pulling the fuse. I later found out, that some how, my replacement fuse had been broken (not burnt out).
Replacing all of my fuses in the exterior box, has my instrument cluster back up and running.
Unfortunately, one of the wires has melted all the way up the dash, to where the prev owner spliced into a wire BEFORE the fuse box. So i had to run that wire all the way from the trunk harness to under the dash.
Water leaks have been repaired with some good ol' RTV & patience.
Finally attacking the EVAP. Going to pop it open and replace the Charcoal myself, to avoid the hefty price. Looked up online, and some people have had success with getting it open and plastic-welding it back together.
Will post update.
I ended up putting off this car for quite some time, as i moved into a location where i had to work on the side of the road, and my tool box was 4 flights of stairs away from where i had parking. Finally in a place that has a parking spot! woop woop
Reactions: gkomo and squeak93
Interior and Upholstery Water leak, passenger side, ripped seats and carpet out already.
  • 2000ElectricGreen
  • Mar 18, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 24, 2026
squeak93
T
2002 V6 3.8L Help Me
  • TheIncompetentMechanic
  • Apr 4, 2026
  • 2 3
2K
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
T
M
  • mnky99
  • Sep 5, 2025
mnky99
M
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 6, 2025
J
2000 Ford Mustang GT No Crank No Start please help
  • Jowen216
  • Jun 5, 2024
  • SN95 4.6L Mustang Tech
3K
SN95 4.6L Mustang Tech Jul 5, 2024
Jowen216
J
