Emission testing-messed up injector?
  • Thread starter Thread starter grey5.0beast
  • Start date Start date Sep 21, 2004
grey5.0beast
Cookies should never be DUNKED!!!
Aug 3, 2004
atl ga
Sep 21, 2004
  • Sep 21, 2004
Ok well heres the story. I took my car to get tested for emissions and while I'm driving home i hear a clicking sound from when it was started. I looked under the hood and listened to the engine in idle and I heard a clicking sound from the first injector(closest to front) on the left. I'm thinking it is injectors but I'm not sure. Any way, what is involved in emisions testing? I thought they just hook up a thing to your exhaust and watch a meter and rev it or something, but what else could it be? I'll get into it tomorrow and pay a visit to those guys to ask them what happened and if it did it during testing. Sorry for it being so long.
Z
zingi4532
9
  • Sep 21, 2004
Sounds like maybe the spark plug wire for cylinder 1 might have gotten unplugged- have you checked that? During an emission test, they usually put a clamp on the #1 cylinder wire to get an accurate rpm reading- that's the only thing i can think off-
Good luck
grey5.0beast
Aug 3, 2004
atl ga
Sep 21, 2004
  • Sep 21, 2004
thanks I,ll be sure to check that.
grey5.0beast
Aug 3, 2004
atl ga
Sep 21, 2004
  • Sep 21, 2004
Well, I checked the first spark plug wire and thats not it. so please keep the ideas coming. Thanks
HISSIN50
34
129
Sep 22, 2004
  • Sep 22, 2004
when an injector clicks, it generally means it IS working. worry if it does not click. have you used (carefully) a stethoscope or other instrument to find the noise? i liked the plug wire idea. if it becomes slightly unseated, it will make a popping as the spark is discharged.
i might start the motor and turn off the lights and see if you see any lightshows from the wires.
good luck.
giddyup306
3,041
Sep 22, 2004
  • Sep 22, 2004
How do you know it's the injector anyways? Did you put a stethoscope on it to make sure was the injector and not something else? The emissions varies from state to state. For the most part they just stick a 5 gas up the tail pipe and run it under a load on a dyno. Some states also check for evap. emissions by looking for a faulty gas cap or even for HC's around the vehicle. Pretty harmless tests. It is probably not the emissions guys fault.
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
A
Resolved Fuel Pump issue - test port jumped comes on (87 LX)
  • afjLX
  • Nov 16, 2024
2K
Fox 5.0 Mustang Tech Nov 26, 2024
afjLX
A
O
injectors keeping up?
  • optionizerSS
  • Apr 4, 2025
2005 - 2014 S-197 Mustang -General/Talk- Apr 4, 2025
optionizerSS
O
P
Progress Thread New To Me 1988 GT - trying to set up vacuum lines for upper intake question
  • pindude80
  • May 6, 2025
  • 9 10 11
15K
Fox 5.0 Mustang Tech Mar 28, 2026
pindude80
P
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
