• Community Forums
  • Regional Forums and Event Information
Emissions testing questions
  • Thread starter Thread starter boomr
  • Start date Start date Sep 28, 2005
boomr
51
WA
Sep 28, 2005
  • Sep 28, 2005
I know this has been talked about before, and I've done a search. Maybe all was lost when the site crashed earlier this year. I'll be moving to WA next summer and am wondering on the Emission's testing procedure. Do they do a visual, tail pipe, load test? Just trying to get an idea of what they look for. Mostly concerned with aftermarket mods, engine, exhaust, intake, turbo's, etc...
gospeedgo
Banned
Aug 14, 2003
978
Gresham, OR
Sep 28, 2005
  • Sep 28, 2005
On a Fox, they will check the gas cap, then have you pull it onto the dyno, and they will have you drive it at 20-25mph in 2nd or 3rd and sniff it. Then, they will have you let it idle and sniff it again. Then they hand you a pass slip and send you on yor way. Very easy to pass WA.
99GTtony
346
Seattle,WA
Sep 28, 2005
  • Sep 28, 2005
^^^^ There ya go.
It's easier on newer cars, they just plug into the port, and as long as you dont throw any codes, you're good to go. No sniffer, no dyno.
gospeedgo
Banned
Aug 14, 2003
978
Gresham, OR
Sep 28, 2005
  • Sep 28, 2005
yup..96 and newer, dont even need cats (well, you DO legally...but it will pass without 'em) as long as its chipped or flashed. They dont inspect. No popping the hood unless your cigar lighter port dont work, they go right to the battery.
boomr
51
WA
Sep 28, 2005
  • Sep 28, 2005
The car's a 91 fox, no codes flashing on the car. I did find the WA emissions web site, but doesn't really answer the questions, or I just didn't look in the right spot. Thanks for the reply's.
99GTtony
346
Seattle,WA
Sep 29, 2005
  • Sep 29, 2005
Being a 91 they'll put the sniffer on it, and a gas cap check. As long as you have cats in good working order you shouldn't have any problems. Where in WA you moving to?
boomr
51
WA
Sep 29, 2005
  • Sep 29, 2005
Cat's are in place, should be ok than, thanks. On the gas cap check, are they just looking to see if it's there, or are they looking to see a sealed fuel system? Probably be over in the Poulsbo, Silverdale, Bremerton area.
C
candersts
  • Sep 29, 2005
I live in Silverdale. I haven't had to get an emissions test. i have a 95 GT with no cats.(but it has issues). I have had no problems with anyone questioning it. I do believe Kitsap County doesn't require emissions testing, but don't quote me on that.
99GTtony
346
Seattle,WA
Sep 29, 2005
  • Sep 29, 2005
The gas cap check is to make sure the system is pressurized and not leaking fumes into the air. Even if it fails, there are ways of still getting your car registered, they are explained on the back of your emissions test results.
Smoke'm
41
Bothell , Wa.
Sep 29, 2005
#10
  • Sep 29, 2005
  • #10
use 3rd gear..the tech told me they sniff better that way I went through no problem in 3rd and I was worried.
he just said to make sure I do it in third next time as well, shouldnt matter.. but hey free advice can be a good thing, especailly when your at the station being sniffed!
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 11, 2026
02_2v_Curtis
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
Engine Throwing codes 94, 33, 34, 44, and sporadic engine shutoff.
  • Ryu
  • Oct 9, 2024
Fox 5.0 Mustang Tech Oct 16, 2024
89ripper
  • Community Forums
