Ok so I went out and got something done.
found a press in bushing that fit after some step bit work. A 5" holesaw seemed to be the right tool.![]()
would be perfect If the pulley wasn't so close to the ring size... I'm afraid the sensor may not like it.![]()
I will figure something out..
If you have 7" hole saw, make a spacer out of suitable material and thickness. Once it is cut out, use the 5" hole saw to make another hole. Now you have a ring to act as a spacer between the timing wheel and the balancer or pulley. I would try 2 pieces of 1/4" aluminum plate as material for the spacer. It is non-magnetic and isn't likely to play havoc with the sensor and the magnetic field that triggers the sensor.
You think outside the box...That's why...If I can cut the center out of the damn thing in less than 20mins start to finish with close to no equipment. How can a fully equipped shop not be able to.?
