fastest stock blocked N/a 94-95 vs 96-98
do strokers count? some use the stock block...
TMC (Troy) he ran 11.6 @ 118 NA on stock shortblock... I doubt if you will find many to beat that.. I didn't even come close to that with my stroker...
i have a basically stock 96 with 4.10s :nice: it has pulleys and a timing adjuster.
i also have a 95 with ported stock heads, trick flow street heat intake, pulleys, equal lenght shortys, and catback. :nice: i don't know what gears it has. the guy i bought it from said it was 3.73s but i'm not convinced. :shrug:
i just got the 95 from the shop today after the headswap.
the 96 feels much faster than the 95. :bang: i really thought the 95 would be much faster, but right now it doesn't seem to be.
well not to bring up another debate but.... I am not much of a believer in thumper heads... I have seen the dyno graphs from them and i just don't think its fair to judge that car because basicaly you still have stock heads, maybe not as restrictive but none the least they don't flow/perform anything like a set of TFS or AFR's.
blown93feature said:
I'm still laughing over the 11.6@118 anybody have a video of this or maybe a time slip+weight slip+mod list?
This is supposed to be n/a correct with stock short block bla bla bla???
TFS heads and a monster cam, revving it to 6600 with a 4.30.
Joe
Or you can check out his mods here http://home.comcast.net/~nmrastocker/95GT.html
Black96VertGT said:
according to his mods, since he doesn't say anything about the cam, i guess that means he has the stock cam still.
I think you missed this.
"Erson 226/234 - .568/.568 – 110 lsa cam"
I wouldn't call that a crazy cam, but it certainly has a nice lope. The duration isn't crazy or anything.
Scott
Well, the 96-98 can run 11 easy. And there are many guys doing it, take some stock 99+ Heads, Port them, get some cams, all the Bolt-Ons and Headers, get some suspension work done, lose some weight, and your done. The car will make about 320-330HP and run low 12's high 11's depending on traction ect, once the 99 herads go on the 96-98 cars there is really no dif between the 99+ and 96-98, except the 96-98 will have more comp. Go to www.modulardepot.com and check out some of the NA 4.6 cars, there is some guys running 11's on STOCK heads. Just cams and bolt-ons.
I want to say that if it has happened thats great and my hats off.I did not put out the :bs: because maybe he's able to get that less than 2700 lb car to go that fast,I'm assuming that it weighs less than that!!
There is a guy around here by the name of rodney that has a 03'mach that weighs in at a tune of 2900lbs.This guy is an awesome driver with a ton of seat time with his car and pulls 1.50 shorts with it.I have seen this car dyno and has put 313rwh/329rwt.The best time to date is 11.98@113 so thats why I say if this guys car isn't under 2700 with him in it than he's hard pressed to go [email protected] n/a with a 1.57 60' and not to mention that rodney's car has 430's a ton of suspention and will rev all the way to 7000.
