throttle position sensor never went above 0.2% when closed.. and closed loop is at 2.0% , but i switched out Tps's with one that had more wiggle room. so now my tps is on 0.0 sometimes -0.2 which i can live with. and as for the lean spots i pulled the plugs and they all are showing normal colors... No white -no black. nice brown color, except for a little black from when it was super rich. but im going over everything once again today, and i made some changes to my intial values table.. basically added 5 points to the first box then interpolated each line. so hopefully that helps catch the idle when i lift. cause to me it seems like the valve isnt open enough to have the idle settle above the target and fall into place. so i did make some adjustments last night but havnt tried them yet. Also the lean spots arnt at steady throttle or nothin.. More like shifting gears.. Also its not consistent..
