fox lean?
  • Thread starter Thread starter Mr. Rustypwnz
  • Start date Start date Sep 23, 2007
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
indianapolis/ valdosta ga
Sep 23, 2007
  • Sep 23, 2007
I think my vert has the "fox lean" it leans about an inch and 1/2 to the left side, but only in the rear, the front is perfect!! the rear is just tweaked a little though it looks like, I took the shocks off today, and they are fine, ive narowed it down to the springs and isolators, cars never been in anykind of accident. what do you guys think it could be?
93GTosu
183
  • Sep 23, 2007
i've been trying to figure this out forever. mine is the sadly the same.
i've read that if the springs are "clocked" wrong it will cause a different height on one side or the other. I havent found anyone who's actually attributed the "lean" to this however.
i imagine it could also be because the chasis isnt exactly the stiffest and was probably "tweaked" easily at one point or another. I have no $$$ or time however to replace parts and look for the culprit.
so for now i look like i weigh 500lbs going down the highway.
bennettracing
280
Ava, MO
Sep 24, 2007
  • Sep 24, 2007
lol, I'm sure this is no help to you guys, but I've been reading the threads on this for a long time, and thought my project car had the same problem... One day I switched the left rear tire to the front on accident, and noticed the lean went away! Booo bad tire! Gotta love the simple things (in my case anyway!)
Bottomlesspit
I started the longest tech thread in the known uni
2,636
Del Rio, TX
Sep 24, 2007
  • Sep 24, 2007
I had the same issue on my old 93 vert. It is true that if the springs are not clocked properly you will get a slight difference in heights on each side. I was able to get mine "close" by clocking the spring pigtails in the correct position, but still had a bit of difference. I finally got it totally leveled by cutting a 1/4 length of coil (from the top coil) from the taller side. If I remember correctly, I had to cut a 1/4 coil off twice before it leveled...meaning I removed 1/2 of a coil. The key idea here is not to be tempted to cut what you THINK you need off the coil. A little goes a long ways! It remained level until I sold it 3 years later.
Good luck.
Ken
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
Sep 24, 2007
  • Sep 24, 2007
ok well good thing im putting sfc's on it and swappin the springs out this week lol. well I guess I should get at it!!
F
Fox8950
247
Sep 24, 2007
  • Sep 24, 2007
I'm pretty sure this is a common enough problem I know for a fact I've seen a spacer they sell to put under the rear driver side spring to compensate, I will try to find it again.
**http://www.globalwest.net/mustang 79-98.htm scroll down a bit and there u go.
Mikey1968
232
Kommiefornia
Sep 27, 2007
  • Sep 27, 2007
My 86 Capri had a lean since I bought it in 88....got one of these spacers, now it rides nice and level. Measure twice, then order the one you need.
Pretty easy to install......
87pony
69
  • Sep 27, 2007
some of the lean in the back is due to the fact that there is always someone sitting on the drivers side, and not on the passenger
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
N
Fox Street Suspension Build Advice
  • NYFox
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 28, 2026
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Suspension Rear driver side sits lower than rear passenger side...?
  • 91GTstroked
  • May 15, 2024
3K
Fox 5.0 Mustang Tech May 18, 2024
91GTstroked
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
