fuel injector size/brand
hey everybody new to this site, looking for first hand info if anybody has it. I have an 89 5.0L with a paxton NOVI 1000 supercharger running round 6lbs boost. i have got most of the little upgrades to go with it but i am getting a bigger fuel pump and injectors. my questions is what size injectors should i go with and anybody have preferences on brand?
any help would be greatly appreciated.
The stock style Bosch injectors are just fine for your application. Assuming you're running an FMU (Fuel Management Unit) on the fuel rail, you should be able to run your stock 19lb injectors without issue for all the power your car will be making. If you plan on ditching the FMU and going with an ECU tune instead, I'd go with a minimum 30lb/hr units. Those should be sufficient for your power needs. You should be able to find them on Ebay for a couple hundred dollars.
