I just swapped out the fuel pump on my '93 ragtop. If you're about to do the same and you don't have a buddy to help you, 20 minutes making this is gonna make your life sooo much easier!
Materials required:
Scrap lumber
Screws
1" pipe nipple
3/4" x 3" bolt/nut and 2 washers
Dimensions are 19" x 36".
Cut a piece of 3/4" plywood 12" x 12" and screw it to the back. Drill/cut a slightly oversized 1" hole and pound in the 1" pipe nipple.
Now you'll need an older floor jack with a lift out saddle. If not, I'm sure you can figure out a way to attach it.
Secure the fuel tank cradle to the jack with the 3" long 3/4" bolt/nut/washer combo and you're ready to go to work!
These pics are from when I did my '89 but I've used it 3 times since then including this past weekend when I did my '93 and I had 3/4 of a tank of gas in it! It doesn't fall over or wobble side to side because it's securely mounted to the jack. It fits all '87-'93 Mustangs. If you have a different tank in a different car, just size it to fit that tank. This makes it truly a one man operation! Thought I'd share, hoping it'll help somebody out.
Materials required:
Scrap lumber
Screws
1" pipe nipple
