Fuel upgrades, car won't run. Need help ASAP! :(
  • Thread starter Thread starter Ozz
  • Start date Start date Apr 12, 2004
  • 3
  • 4
First Prev 3 of 4 Next Last
Ozz
I think I have a problem here.
3,514
66
109
Canton, MI
Apr 15, 2004
#41
  • Apr 15, 2004
  • #41
I will try that. Is there a wire to trip to pop it, or am I going to have to start beating on my poor car?
Grn92LX
Fidanza Man!
6,819
64
129
New York
Apr 16, 2004
#42
  • Apr 16, 2004
  • #42
bang the inertia switch with your hand until it pops, then reset it. Its easy to try.
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
Apr 16, 2004
#43
  • Apr 16, 2004
  • #43
Hi Dave,
Reading through everything and seeing what you've checked and the direction you've gone, I can't help but wonder if it's something a little more mechanical. I know you said you just changed the fuel pump -- and I know you had some trouble with it, I wonder if maybe one of the lines was pinched and caused problems or something of the sort?
Going throuhg all these tests seem to be leading in circles, and that usually indicated being on the wrong path to me. I might want to start all over and recheck everything starting with what you've changed, start changing back the easy things -- like maybe swapping the MAM back to stock, see if it acts different, etc.
Ozz
3,514
66
109
Canton, MI
Apr 16, 2004
#44
  • Apr 16, 2004
  • #44
What I discovered today:
With everything connected, the fuel pump would not prime when I turn the key to On.
With the TPS plug disconnected, the fuel pump WILL prime. I put in a replacement, set it, and it started but died out in a second. It idled fine w/o the CE light coming on, but simply died out.
So now since I found what the problem was (after too long of searching), and going to get a brand new one to put on, what else should I check in regards to making it run?
The injectors are getting a pulse, the injector harness ground is grounded. I took the upper intake off completely to be able to work down in that area to find it, and finally did. Now I know where it is.
Suggestions? I hate to say I think we're finally getting somewhere but I think we are.
Adam - I was close to yanking the fuel pump again, thank God I found this before doing so. (especially since I added some gas!)
Mike86Stang
Advanced Member
Apr 11, 2000
10,296
Red Lion, PA
Apr 16, 2004
#45
  • Apr 16, 2004
  • #45
Just check your v-ref to make sure where it's supposed to be. Check the voltage on the TPS to make sure it's within spec.
As a side note if you ground your v-ref signal the pump should prime every time.
Ozz
3,514
66
109
Canton, MI
Apr 16, 2004
#46
  • Apr 16, 2004
  • #46
Will do. What about KEEPING the car running?
T
Tstang90
2,380
Long Island,NY
Apr 16, 2004
#47
  • Apr 16, 2004
  • #47
Glad to see your making some headsway there!
Ozz
3,514
66
109
Canton, MI
Apr 16, 2004
#48
  • Apr 16, 2004
  • #48
Kinda.. :rollseyes:
BlackFox5.0
3,514
Massachusetts
Apr 16, 2004
#49
  • Apr 16, 2004
  • #49
Are you sure you didn't maybe pinch a fuel line that goes across the top of the tank? Maybe the fuel pump is able to fill the line with gas all the way up to the engine, but once the engine is running it drains out the line before it can fill up because it's pinched. Just trying to think of something....
T
Tstang90
2,380
Long Island,NY
Apr 16, 2004
#50
  • Apr 16, 2004
  • #50
You runnin a Trex?? I forget if so its eay to kink those lines.
Ozz
3,514
66
109
Canton, MI
Apr 16, 2004
#51
  • Apr 16, 2004
  • #51
IT'S ALIIIIIIIVE!!!!!
The TPS and EEC were shot. Put in a donor EEC and it idled, although awfully. So tip #1 mine was dead.
Luckily my dad had ordered a replacement for mine thru a shop and had it delivered, so I went and picked it up (even though i had already ordered ANOTHER thru the 'net, lol...ebay time) , put it in, and BAM! It works! Of course a new TPS helped too, but damn it, it is done.
I was NOT expecting to get it finished at all, but thanks to you guys, we got 'er goin'!
Thanks again to all who have helped and spent time typing the info & thinking it up.
This was really a pain for me.
rbridges
78
warner robins, ga
Apr 16, 2004
#52
  • Apr 16, 2004
  • #52
tps AND eec were shot? is that common. It's always hard to diagnose problems when more than one thing is the culprit.
well, I'm happy for you. it can be frustrating at times.
BlackFox5.0
3,514
Massachusetts
Apr 16, 2004
#53
  • Apr 16, 2004
  • #53
looks like you'll be at the show after all
89MustangGX
Jul 3, 2001
10,262
Mill Creek, WA
Apr 16, 2004
#54
  • Apr 16, 2004
  • #54
Glad you got it all resolved -- wish I could have helped more. Nowhere in my train of thought would I have come up with the computer and TPS -- almost makes me wonder if it was some type of power surge or something that took them out...certainly first one i've seen like that!
ALMOST STOCK
1,250
41
88
CA.
Apr 16, 2004
#55
  • Apr 16, 2004
  • #55
Hey Dave
Glad to hear you got your problem solved
T
Tstang90
2,380
Long Island,NY
Apr 17, 2004
#56
  • Apr 17, 2004
  • #56
Dave thats awesome. TPS huh
Its odd how they both went at the same time.
Now you can move on.
See ya in PA man!
M
mackey
1,284
Beverly, Massachusetts
Apr 17, 2004
#57
  • Apr 17, 2004
  • #57
Where is this show I just bought some new stainless Flowmaster american thunder exhaust system for $250 new! I am syked to get this in.
Ozz
3,514
66
109
Canton, MI
Apr 17, 2004
#58
  • Apr 17, 2004
  • #58
The show is at Mustangs Unlimited in CT. But I won't be there with the car unless miracles happen in the wee hours of tonight
I put the new computer in, new TPS, and it started running perfectly last night. Yay! Started it a couple times, pulled no codes, sweet! Let it sit overnight and I rested.
I came out this morning, cranked it, and it dies. It won't run at all now. I touched nothing in the meantime!
First it starts and dies immediately. Then if I start the car again, it will rev itself up to the redline. The 2nd time that happened, it buried my tach.
Fuel pressure is constant, if that matters.
Any ideas?
Looks like I'm missing tomorrow's show, but now I've got to figure this crap out again so I can get my tune next week!
Mike86Stang
Advanced Member
Apr 11, 2000
10,296
Red Lion, PA
Apr 19, 2004
#59
  • Apr 19, 2004
  • #59
Sound like maybe you dist/PIP is bad. fuel pump still prime ok?Maybe your TPS is still giving you fits... check the voltages again? Last but not least disconnect your IAC & adjust the throttle plate so it will idle without the IAC. It'll keep it off red line till you have it figured out.
Sorry to hear about the crappy luck!... if it's any conselation it's the same luck I ussually have
Ozz
3,514
66
109
Canton, MI
Apr 19, 2004
#60
  • Apr 19, 2004
  • #60
Thanks
We got the redline situation figured out. Dunno what the hell was causing that
Now, though, it just starts and dies. We can get it to idle for a while but we have to keep kicking the throttle up. It will not stay running at the same idle speed, no matter how high or low. As long as we keep it moving up and down, it will contibue running.
I will try to get it going with the IAB off.
What is a PIP?
  • 3
  • 4
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Engine Fuel not pumping
  • Creomod
  • Apr 13, 2026
  • 2 3
Fox 5.0 Mustang Tech Jul 22, 2026
Need help asap
  • shaggyman65
  • Dec 24, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 24, 2025
shaggyman65
L
Engine Why won't the motor start if I have spark and fuel
  • LeviAnderson
  • Nov 20, 2025
Fox 5.0 Mustang Tech Nov 20, 2025
AeroCoupe
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
