Hi,
I have the 2030 cam, 3.73s with an AOD and 2500 RPM stall converter. The cam gives a nice flat torque curve which is good for the street. I'm pretty happy with it.
Good Luck, Don
Engine: 306 ci w/ timing at 18*, Sterling pistons H273CP w/8.9:1 compression, FMS Harmonic balancer, Edelbrock 6037 heads w/2.02" intake valves, Edelbrock performer intake manifold, FMS 1.6 roller rockers, Crane 444221 (2030) 216/220 @ 0.05" with 112 lobe separation 0.533"/0.544" lift, FMS aluminum radiator, Lincoln Mark VIII electric fan, Performance Distributors TFI and Screem’n Demon coil, FMS 9mm plug wires, March Power and Amp Pullies & 3G 160A alternator.
Fuel and Air: 24# FMS injectors, Edelbrock 70mm TB, C&L 73mm MAF, stock fuel pressure regulator, 195 lph fuel pump, MAC CAI.
Exhaust: 1 5/8" BBK ceramic coated headers, MagnaFlow SS 2 1/2” catback and X-pipe w/Cats.
Drive Train: D&P Products 2500 RPM stall 9 1/2” torque converter w/damper, AOD w/ TransGo HP shiftkit, Earl’s 19 row transmission cooler, FMS 3.73 gears, FMS aluminum driveshaft.
Wheels and Tires: 17” x 9” Replica Cobra R, 555R Nitto Extreme Drag Radials 275/40ZR17 rear & 235/45ZR17 front.
Brakes: Hawk HPS pads, Front 73mm calipers from 1991 Lincoln Mark VII, Rear MM Shoes, Sn95 MC w/3-2 port conversion & Russell SS hoses.
Chassis: FMS Subframe connectors, FMS upper control arms, MM lower control arms, Energy Suspension engine, transmission and front sway bar mounts.
Appearance: Design Concepts Cobra Grille Insert.
