I just got an engine for $150.
1988 Mustang GT 5.0 H.O.
Forged pistons
double chain
It has low compression in 2 cylinders due to a blown headgasket [so the guy says] and it's the complete longblock minus the timing chain cover and the alternator.
I plan on adding a set of GT40 or GT40p heads, a E303 or B303 camshaft [anyone know the difference and how they are?] or the steeda #19 camshaft...I would like something more agressive that will take advantage of the engine a little more. I was looking at cobra or GT40 heads for a while but noticed that I can get a trickflow intake for about the same price which sounds better. I'd like to keep this below $1300ish. I found the camshaft(s) on summit for about $160, the intake for $500ish, and can probably find a used set of heads for about $300.
Now what I wanna know:
-What type of injectors should I use?
-What MAF/throttle body? I was thinking about a 70mm from professional products?
-Will it be okay with my transmission?
-it will fit under my stock hood, right?
-is there anything else I can do to add more power and strength to this engine? I'd like to add nitrous later... a 100 shot of dry.
Also, I want to go outside right now and start taking the heads off and inspecting it.. Is there any special way to remove the heads? what about the lower intake manifold and the injectors? should I sand down the top of the engine so I get any pieces of the head gasket off?
Help/info/suggestions? I know tons of you have done this before... Help me out here!
Thanks!
oops...Edit:
I forgot, should I add in a tweecer? am I able to get it up and running fine without a programmer? Will I have enough power to compete with newer cars such as the 99+ GTs? SRT4s? WRX STi's? etc.... est. HP? times? etc...
Forged pistons
double chain
Thanks!
oops...Edit:
