Gt40 heads and a Cobra intake...
  • Thread starter Thread starter MY 85 GT
  • Start date Start date Apr 13, 2009
MY 85 GT
1,852
208
104
New Jersey
Apr 13, 2009
  • Apr 13, 2009
Ok im going to use a set of Cast iron GT40's and a Cobra intake...with a 70 mm TB....and im using the stock cam with a set of 1.7 cobra roller rockers anyone run a combo simular to this? How does it run....did you ever take it to the track any times?....Im going to have also a Paxton SN93 blower making 6 psi and a powerpipe that should up the boost a little....Im also converting it to MAF.... using 24# injectors..And an adjustable aeromotive fuel pressure regulator..And a FMU calibrated to the 24# injectors....I hope this should run some decent times...Im also going to be installing a 6 point roll bar and subframes...i hope that help stiffen up the body....also not decided on what gears 3.73's or 4.10's any help would be great....
SteedaGT9150
Advanced Member
Nov 10, 2004
1,351
59
68
Maryland
Apr 13, 2009
  • Apr 13, 2009
MY 85 GT
1,852
208
104
New Jersey
Apr 13, 2009
  • Apr 13, 2009
SteedaGT9150 said:
15.6
HUH?.....do you mean on the motor or with the motor and blower it will run 14.2?....isnt that a little slow????
MY 85 GT
1,852
208
104
New Jersey
Apr 13, 2009
  • Apr 13, 2009
MY 85 GT said:
HUH?.....do you mean on the motor or with the motor and blower it will run 15.6?....isnt that a little slow????
15.6...how could that be?
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
indianapolis/ valdosta ga
Apr 13, 2009
  • Apr 13, 2009
damn lol
that on motor should bust a 12.9 if you can drive
low 12's on boost..
SteedaGT9150
Advanced Member
Nov 10, 2004
1,351
59
68
Maryland
Apr 13, 2009
  • Apr 13, 2009
just ****ing with you man lol
ryan218
In just 10 years, I'll be old enough to drive!!!!
Dec 28, 2005
columbus ohio
Apr 13, 2009
  • Apr 13, 2009
id think you will need more fuel then that? bigger injectors, 42's at min id think?
M
Makdaddymac
323
orlando
Apr 13, 2009
  • Apr 13, 2009
i have same exact combo. no boost. i know i gained some hp, but imo the cost and work could've been more worthwhile on some more aggressive heads and a cam. i know my car is 12 second capable. 13's with me driving. but i cant prove it so i'll shut up till i take it to the track.
overall its runs faster than the new stock gt's and i'm happy with that since i have less than 3500 including the car with my fox.....
KamiKaziDK
555
Mesa, Az
Apr 14, 2009
  • Apr 14, 2009
42s would be HUGE for that combo, 30s or 36s would do just fine
strtrcr50
Previously from Dirty Jerzey exit 7a
Apr 14, 2009
#10
  • Apr 14, 2009
  • #10
60's are one of the easiest injectors to get dialed in in a tune. It really doesn't matter the size unless you are making it work with a matched MAF.
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Apr 14, 2009
#11
  • Apr 14, 2009
  • #11
12.14 @ 111 with GT40Ps, Cobra Intake, and a stock cam.
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Apr 14, 2009
#12
  • Apr 14, 2009
  • #12
42's would give you room to grow, and you will want more power onve you get used to what youve got
stykthyn
5,232
2,652
223
gainesville
Apr 14, 2009
#13
  • Apr 14, 2009
  • #13
dont waste time with the cobra/gt40 set up. seriously step up to a set of more aggressive heads and a custom ground cam. you sound like you want to get the most out of this blower and restrictive iron heads with a stock cam are not going to get you there.
RYC CUKR
1,437
Orlando
Apr 14, 2009
#14
  • Apr 14, 2009
  • #14
I ran P heads, GT40 tubular, 70mm TB, stock cam and 4.10s and went 14.0s on my 93. Keep in mind this is an aod with the stock converter in a GT vert so the launches were killing me and the added weight didn't help either. trap speeds were right at 100mph.
white 89 GT
281
Tacoma
Apr 14, 2009
#15
  • Apr 14, 2009
  • #15
That stock converter must be the problem, my 89gt AOD car ran 14.94 then I started to make changes it finally ran best 13.25 and 104 mph with 3.73`s, 2600 stall, 4r70w gearset, shorty headers,typhoon intake, 70mm tb, 73mm mam,tw heads,1.7 rr, and crower 15511 cam. no traction type tires and 2.5 exaust.
Get a converter and try the 4r70w gears in your aod and it will launch mo better.
KamiKaziDK
555
Mesa, Az
Apr 14, 2009
#16
  • Apr 14, 2009
  • #16
That seems super slow even for a gt vert.....
Very true
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
11K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
