GT40P cc size?
higher compression of course....but you may have to retartd the timing a bit and/or use better gas.... and check piston to valve clearance again, may not be milled much but better safe then sorry.... and if you dont have the heads yet, you need MAC tru fit shorties or MAC longtubes or FRPP "P" shorties....
If you mill the heads 16 thousandths..you will have a 57cc head...the P heads are 59cc stock...I would guess you would have a 10.5 to 1 compression motor...but you might ought to check you piston-valve clearance to make sure you have enough clearance. 7 thousandths equals to 1 cc when milling...good luck... those are good heads I have seen guys run low to mid 11s....
