GT40P Combo Porting Advice
  • Thread starter Thread starter Street89GT
  • Start date Start date Feb 21, 2010
Street89GT
55
  • Feb 21, 2010
I have a set of GT40P heads and a tubular GT40 Upper/Lower. The lower has been port matched to a set of Trickflow heads by a previous owner. The ports are slightly taller and wider then the ports on the GT40P Heads. Would it be a good idea to port match the GT40P heads to the lower intake? I can post up pictures if that would help. Thanks in advance!
95BlueStallion
My assy trans to myself
5,130
3,103
214
Cedar Rapids, Iowa
Feb 21, 2010
  • Feb 21, 2010
I would. But when you do it, only port about a half inch to an inch or so into the intake runners on the heads. Also, you dont want to smooth the intake runners, because the air/fuel mixture needs to be "shaken up" as it passes through for optimal burning. If you smooth them, the fuel will enter as bigger droplets and not burn as well.
Street89GT
55
  • Feb 22, 2010
Thanks for the reply. Will there be any adverse affect if I don't port match the heads to the lower intake? I measured and the lower intake ports are about 3/32" wider and 1/16" taller then the intake ports on the heads.
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
5.0 Rebuild
  • smittys7up
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 16, 2026
keel
D
No start
  • dkrupp79
  • May 31, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2025
dkrupp79
D
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
Block questions
  • s_vargas54
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 8, 2026
Trogdor
