I don't know if that is totally true. I am pushing around 285hp to the Rear wheels and I have a very mild combo. I bet you could get 350hp and keep it very streetable. But, supercharging it would definetly get you the power you want. It is true that with the Trick Flow R stuff that you are going to kill bottom end, 2500 to 6500 is what the R is at I think. Then you would need to strengthen up your bottom end for reliable power. I think with a good set of AFR's, a good intake, T/B, injectors, mass air meter, gears, cam, underdrives, and various other small components, you could make those numbers. But I could be wrong.
