I did a search, but not too many people have my exact combo. Anyway, I can get a good deal on a TrickFlow stage 1 cam. My knowledge on camshafts is close to zero, so I need a little help deciding if it is worth swapping my cam with the modifications I have(mods in sig). This car is also a daily driver, so I need something with a good idle and good street habits. I was planning on replacing the gasket on the timing chain cover so I guess now would be a good of time as any to swap in a cam. The only other thing I plan on doing to my car(for now)is adding a nitrous kit; will this cam work well with a nitrous kit? So what do you guys think so I swap out the cam, or stay with the stock cam and use that money somewhere else? Thanks
Victor
Victor
...just make sure you have all your gaskets when you go to do the swap, and reset your base idle and timing to accomodate for the slight increase in duration and lift
