Not many choices in a 225 40 17....more options in a 225 45 17 and it is closer to the stock size. You also prob would not need -1 camber to run this tire.
They have that size in the tire I am looking at but now after 68EFIVert's comment below I think maybe the 40 series may not have the thickness I'm looking for. I guess I'm just confused.
At first I was looking at a 245/45 17 for the front and was told that it would prob be too big and look out of place when running a 275/35 18 on the rear. And now a 225/40 17 is way too small. How about a 235/45 17 for the front?I to would look for the 45 series front tire in a tread you like. The 40 series may look a little to "tuner" for my preference. The sidewall starts getting pretty small. It would give you a nice raked look to the car though and shouldn't pose any clearance problems. You may want to consider dropping down to a 7" wheel if you go to a 225 tire. I did and it gave me a little more assurance I wasn't going to hit the fender. If you do then go to a 4 1/4" bs on the front wheels. I think I forgot to mention earlier that my 18*9 rear wheels have a 6" bs. There is plenty of room on the inside and outside with the 275/35/18 tires.
Yeah I wasn't sure if the profile would be too low or not. Would a 235/45 17 up front match well with a 275/35/ 18 in the rear and run the -1 camber?
Also, the rear wheels have a 5.94 backspacing and the fronts have 5.72 in which I know that I will have to use a 1 inch spacer.
You guys are awesome in trying to help me out with this tire and wheel issue. I can't thatnkyou enough.
I understand the allure of a cheap performance tire and that is why I bought them. They didn't work for me. Just conveying that experience while others are simply conveying their own experience with the tires.
