I'm about to install a mechanical water temperature guage. I need to know whether or not I can just replace the stock sending unit with the new sending unit? Or will removing the stock sending unit create problems?
If I can not do that, what are my options? Is there anywhere else, already drilled and threaded that I can place it? Or should I just purchase one of those tee adapters so that I can have both guages hooked up? In my instructions, it says not to use one of them cuz then the fluid can not circulate around the tip of the probe.
What do you guys suggest.
