- May 13, 2006
- 83
- 3
- 9
Details of my car are in my sig, but I just recently finished up doing everything I wanted to as far as mods (for the time being anyways
). Whenever I blip the throttle there is a hesitation, and at idle the engine has a very little shake to it. I also noticed that whenever I'm revving it, black smoke comes out of the exhaust which makes me conclude that it's running a bit rich or loading up. I am running 93 octane gas in it with the timing advanced about 16*. The car runs like a raped ape but with the hesitation it makes it a little harder to pull out at a stoplight or a stop sign. The car also stalls out sometimes when I push the clutch in coming to a stop, which may be directly related, but I think that may be an issue with the IAC valve due to the cam.
It was like this before the mods too but I really didn't mess with it much before. I don't know where to look at. I got the fuel pressure at about 38 lbs with the vaccum line in. The oxygen sensors are pretty much brand new. I'm thinking that either the MAF and injectors are mismatched, since there was a different intake on there when I bought the car, or I might need a hotter spark plug. What do you guys think?
Thanks.
). Whenever I blip the throttle there is a hesitation, and at idle the engine has a very little shake to it. I also noticed that whenever I'm revving it, black smoke comes out of the exhaust which makes me conclude that it's running a bit rich or loading up. I am running 93 octane gas in it with the timing advanced about 16*. The car runs like a raped ape but with the hesitation it makes it a little harder to pull out at a stoplight or a stop sign. The car also stalls out sometimes when I push the clutch in coming to a stop, which may be directly related, but I think that may be an issue with the IAC valve due to the cam.It was like this before the mods too but I really didn't mess with it much before. I don't know where to look at. I got the fuel pressure at about 38 lbs with the vaccum line in. The oxygen sensors are pretty much brand new. I'm thinking that either the MAF and injectors are mismatched, since there was a different intake on there when I bought the car, or I might need a hotter spark plug. What do you guys think?
Thanks.
