Thanks!
My point was mostly that unless the stock intake piping is a real choke on the system, you wouldn't see much for gains. I don't know how much of a choke the factory system is.
So, 1) I was thinking of a CAI and tune. 2) It's probably not fair to say a CAI nets zero gain. Just not the 25 hp gains a magazine article would claim. A tune nets power with the stock system, down to the paper filter. Anyone who gets an aftermarket CAI and tune should see benefits over the factory tune and filter.
Are those benefits related to the piping, the filter, or the tune being more aggressive for higher octane gas? A combination of factors? It's kind of tough to eliminate all the variables so we could say for sure. But it might be reasonable to suggest that real world testing by people without a horse in the race would indicate a CAI doesn't show much benefit at the track, comparing tuned stock to tuned modded. But other mods could very well change the equation. The more power you are making the more gains you see from little changes, changes that would be invisible to an otherwise stock system.
The "Cold Score" article in Mustang 5.0 makes the case for aftermarket CAI's. But one test system, from MMR, replaced just the filter and MAF and saw a 12 hp bump with a tune. Swap in their tube, and get another 3 hp after tuning. It's pretty clearly not the intake tube making all the power there.
The Mac system did pretty much the same thing, replacing only the filter and MAF tube on the end of the factory tubing. 14.4 hp gain according to the article if you compare tuned stock to re-tuned with CAI.
The K&N intake pipe showed 11 hp gains comparing tuned to tuned, but appeared to put the factory MAF into a tube the same diameter as stock.
Among all tested systems, they showed anywhere from 8-18 hp gains comparing tuned stock to tuned with CAI. There seemed little benefit to a whole new intake pipe vs. a factory pipe with a new air filter and MAF tube. Kind of proves the CAI tubing is mostly cosmetic and not really beneficial. But the easiest way to mount a cone filter is to buy a CAI
