I need to take my 91 5.0 in for inspection.
Problem is once gets hot it will not start back up without a 2 hour cool down.
Here is what I have checked so far:
Ran another negative ground from the terminal to a solid ground--still slow/no crank.
Hooked up another battery--Still slow/no crank.
Then I found the small secondary negative wire going from the - Battery terminal to the bolt next to the sellonoid was getting VERY hot.
Hot enough that the tape was smoking a little.
The Negative wire assembly is brand new Ford OEM.
Can someone please chime in..
I only have one more week to get this thing through the DMV...
Oh and I searched also.. with no specific results..
, and often it will short out under high heat. Most of the times voltage drop tests do not catch this problem either.
