The '93-'95 Cobra cam is not the same as a stock 5.0L HO cam. And the latter came in a couple different configurations...
Stock cams:
85-88:
Lift: .278 intake, .278 exhaust
Duration: 266 intake 266 exhaust
Overlap: 36 degrees, 9.04 factor
Lobe Center: 115 intake, 115 exhaust
89-90:
Duration: 276 intake, 266 exhaust
Overlap: 39 degrees, 19.51 factor
Lobe Center: 116 intake, 115 exhaust
91-95:
93-95 Cobra:
Lift: .282 intake, .282 exhaust
Duration: 270 intake, 270 exhaust
Overlap: 33.5 degrees, 15.24 factor
Lobe Center: 115 intake, 121.5 exhaust
Aftermarket cams:
Cam - Duration @ .050" - Adv. Duration - Valve Lift - Lobe Lift - LSA - Int./Exh. Centerline - Powerband
E303 - 220*/220* - 282*/282* - .498"/.498" - .311"/.311" - 110* - 110*/110* - 2,500-5,500 RPM
1.6 Rocker Ratio
Intake Opening: 0* BTDC
Intake Closing: 40* ABDC
Exhaust Opening: 40* BBDC
Exhaust Closing: 0* BTDC
Crane 2030 - 216*/220* - 270*/278* - .533"/.544" - .333"/.340" - 112* - 107*/117* - 2,000-5,500 RPM
1.6 Rocker Ratio
Intake Opening: 1* BTDC
Intake Closing: 35* ABDC
Exhaust Opening: 47* BBDC
Exhaust Closing: (7)* BTDC
Recommended Valve Springs:
Part Number: 99841
Valve Float: 6000 RPM
TFS 1 - 221*/225* - 275*/279* - .499"/.510" - .312"/.319" - 112* - 108*/116* - 2,000-5,500 RPM
1.6 Rocker Ratio
Intake Opening: 3* BTDC
Intake Closing: 38* ABDC
Exhaust Opening: 49* BBDC
Exhaust Closing: 4* BTDC
TFS-51400413 with 1.6 ratio rocker arms
TFS-31400414 with 1.7 ratio rocker arms
