Call the cam company with this info, plus the tranny, rear end gears, and how you want to use it. This is not so radical of a combo. An off the shelf grind will be available for what you want, but it is the same info they need to match a custom grind.Ok so a custom cam then, do you know someone that's reputable for the custom cam? And TLSR?![]()
I think with your good parts, how you are going to use the car is more important than peak numbers.
on!
