My heater temperature output seems to have been dropping off lately. I started noticing it last year but it's really down this year. There is still warm air coming out of it so I'm getting some heat from it but not the scalding hot air I used to get from it - I used to be able to turn the car into a sauna. Now it's just lukewarm to slightly warm air coming out. This problem preceded my intake swap and didn't change one way or the other after the swap. I thought I flushed the core but I may not have flushed it in both directions.
Is there a valve that directs the flow of coolant through the heater core or is coolant always flowing through there? My repair manual is unclear on this.
Other possible causes would seem to be:
Any other places to check for low heat output temperature?
The system doesn't seem to move as much air as it used to either, both A/C and heat so I guess I need to check that out too. The fan does operate at all 4 speeds. Probably a bunch of birds nest under the cowl
- Heater core is clogged and not enough volume of fresh coolant is flowing through it to keep it hot
- Heater core is blocked with leaves and pine needles and not enough air is flowing through it
- Air bubbles in heater core (seems unlikely as it should've worked it's way out sometime in the last 2+ years)
- Flapper valve in ducts is not moving all the way to full heat position and so ambient air is mixing with hot air
- profit!
