I need bigger MASS Air Meter , which one are good
Slow5.0
2,554
Portland, OR
I just bought TFS Twisted Wedge heads , FordMotorsport 1.6 rocker arms , Anderson Ford Motorsport B-31 cam
Now I need bigger injectors 24 or meybe 30lbs (meybe 30lbs looks like little too big) so with those bigger injectors I need calibrated MASS Air Meter
So question is what brand are good , meybe Pro-M , C&L ect.
I just did the 80mm Pro-M ... I searched for the best price and got mine for like $248 or something close to that. They used to be on sale at around $200 ... but it's long done now.
I am VERY pleased with the 80mm Pro-M, if you are planning on changing your injector size around a lot, then go with the C&L like someone else said - but the Pro-M made a noticable change in how my car runs, drives and the better performance it added! I got mine from Performance Parts Mall ... VERY good customer service too!!
Pro-M 80mm hands down it flows more then the 77mm and its cheaper....you dont want to go cheap on a MAF because you will have enough driveability issues with the new heads and cam and dont need the MAF screwing with that.
Spend the moey right the first time and you wont be dissapointed. Just oder the 80mm calibrated for the 20# inj and be happy...the C&L may be cheaper in the future instead of sending the Pro-M back and getting it recalibrated for $100 but the C&L uises the stock/factory electronics while Pro-M gives you their own special electronics....
Anthony
