Who told you it was a loose wrist pin?!?!?! Does it just make a knocking noise!?!?! Ford wrist pins are pressed in, so them coming loose is near next to impossible. If it does make a knocking noise, then what you might have is a rod knock, which is very serious. Imagine the bearings for you 4th cylinder rod worn out, so that you rod is has enough slop to move around on the crank journal. Now, I don't know if what your engine is (289, 302, 351, ECT), but lets say it's a 302 (to make this simple). The stroke on a 302 is 3" (distance from top dead center to bottom dead center). At idle, one cylinder fires about 8 times a seconded, and for every time it fires the piston has traveled though the 4 strokes (not really, but this makes it easier to understand). So, every time the spark plug fires, your piston has traveled 1 foot (3" times 4 strokes = 12") so at idle, your piston moves 8 feet per sec. Now this may not sound too bad, but remember that is this a up and down movement, not in one direction (look at my avatar). You have a piston traveling at 8 feet per sec bouncing around on the journal of the crank, and this is only at idle! You need to get this problem fixed A.S.A.P. If you do have a rod knock, your engine won’t last long.
