i'm having the worst luck lately
  • Thread starter Thread starter Shirley
  • Start date Start date Feb 24, 2006
Shirley
112
Phoenix, AZ
Feb 24, 2006
  • Feb 24, 2006
Last night my 15 year old P.O.S. driveshaft broke. Had to get the car towed home. Just ordered a FMS aluminum from summit. Before this happened I installed my Lakewood 50/50 rear shocks. The shocks were about a 1/2''-1'' too short for the nut to thread onto the upper mount, so I jacked up the rear like a quarter crank on each side to move the rod further up so the nut could thread , and it worked. My question is, did I somehow screw with the angle of the d/s by jacking up the axle a little ?, or are Lakewood shocks just that good? The shocks I pulled out looked like they were from 1991. And also, how tight do you have to torque the d/s flange bolts to? thanks
Euphoric306
905
  • Feb 24, 2006
dunno about the shocks question, but really i dont think it made a difference
what were you doing to break your driveshaft (u-joints im assuming)?? it took that guy on pinks a 4000 rpm launch on slicks and 275 shot of nitrous off the launch to break his stock d/s... dunno how old it was though
HISSIN50
34
129
Feb 24, 2006
  • Feb 24, 2006
If a U-joint had enough slop, that could allow the DS to come apart. Otherwise I am with Euphoric on breaking it.
The flange bolts are 12 mm 12 point. They get torqued to around 100 ft lb. If you reuse them, apply threadlock. Or you can get new ones. Shakerhood just very very recently posted the part number for the new bolts from Ford.
You will lose a little trans fluid too, so have some extra on hand.
Dont run Lakewoods.
Good luck.
Shirley
112
Phoenix, AZ
Feb 24, 2006
  • Feb 24, 2006
yes the rear u joint broke. I had to walk about a block to recover my driveshaft off the middle of the road. For about a week before this happened, I have been hearing a whining noise from the rear, and there has been a slight clunk sound when I engage reverse, or when I put it into park. Why shouldn't I run the lakewoods hissin?
HISSIN50
34
129
Feb 24, 2006
  • Feb 24, 2006
Whoops, my apologies. I meant to say that I dont have feedback about the Lakewood-damper installation since I dont run lakewoods. I guess the rest of the statement would have helped. Sorry. I didnt even see that it read so incorrectly as I sent it. FWIW, I hear they are very nice.
NKau
1,346
Jefferson, WI
Feb 24, 2006
  • Feb 24, 2006
This should have been a sign that you needed to check out your u-joints before this happened. And no, you didn't screw up the pinion angle; your control arms determine that.
Shirley
112
Phoenix, AZ
Feb 24, 2006
  • Feb 24, 2006
thanks guys, and any suggestions on how to torque the bolts to 100 ft/lb without air tools?
NKau
1,346
Jefferson, WI
Feb 24, 2006
  • Feb 24, 2006
I just used a small wrench with a cheater pipe, and really layed into them (don't go nuts here). As long as you use lock tight, you should be OK.
timewarped1972
642
mesa, az
Feb 24, 2006
  • Feb 24, 2006
you really wouldn't use air tools to torque them anyway......a torque wrench with the appropriate socket would work.......
or, lol, clean the bolts, put thread locker on them, put a 12mm wrench on them and when it's tight smack the wrench with a hammer....this will work long enough till you can get a wrench to torque it with, but make sure you re check it the right way at some point .......they do have a nasty habit of losening up......
HISSIN50
34
129
Feb 24, 2006
#10
  • Feb 24, 2006
  • #10
Have your gym-rat friend come help you.
FWIW, I use a 3/8" ratchet, short extension and socket on those bolts. I wouldnt risk impact, as TW said, since those bolt heads dont make me feel warm and fuzzy - it would suck to be not quite lined up and strip one.
Seriously, you could also use your foot to push the wrench.
Good luck.
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
12K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
For Sale 94 Cobra 408w AOD Project For Sale
  • Labora
  • Oct 11, 2024
2K
SN95 Mustangs For Sale (1994-04) Aug 17, 2026
Labora
