injector question
  • Thread starter Thread starter 310stanger
  • Start date Start date Jan 3, 2007
310stanger
170
  • Jan 3, 2007
Ok, I got an injector ques. I have a 310 cu in engine with a trickflow top end kit, 24 lb injectors, 255 lph pump, 80 pro-m meter with pro-m intake tube, stick car all the supporting bolt ons. My friend who I work with (ford techs) suggests that I might not have enough injector for my somewhat highly modified engine. He suggests 30 lb injectors are probably a better match for me. I tend to notice a lot of the build ups in magazines where they are either doing a trickflow kit or a set up very similar to my own ie h/c/i they are using the 30s? Im starting to think I need them because my car which otherwise runs great, does not scream to 6k like i think it should. by like 3500-4k it feels like the power is done and its time to shift. Anyone have any suggestions and advice? preferably based on experiences? I really appreciate this as Im gettin sick of buying things to help rectify this problem. Sorry for the long post. thanks guys
ps. I have what feels like it might be a stock replacement clutch in the car ( Installed by prior owner) and although it doesnt seem to really slip by letting the rpms skyrocket im thinking that the pressure plate jus really doesnt wanna hold the motor. Can a weak clutch make your car feel like its low on power?
D
Dark_5.0
  • Jan 3, 2007
30# injectors wouldnt hurt anything but they probably wont help either. 24's can take you a long way before they become the bottle neck. We maxed out the duty cycle of the 24# injectors at 370 RWHP on a mild 393 stroker.
Yes a slipping clutch can hurt top end performance. You would probably have a burning clutch smell in the car though if thats the problem.
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Jan 3, 2007
  • Jan 3, 2007
You have enough injector to near 400HP (flywheel) change is not needed. Your power figures if the car is in a generally decent state of tune should be in the 280-300 rwhp range which is ideal for the 24's. I would recomend you pull the codes to see if the car is trying to tell you anything then maybe some dyno time to see how your A/F is. As for now...like said pull the codes, get your fuel pressure to 39-40psi and timing to 14 degrees and play a little self tuner with your SOTP meter (seat of the pants meter )
310stanger
170
  • Jan 3, 2007
Thanks for the response man. Im at a loss as to why my car is such a slug lately. Maybe I need to pony up and get the dyno tune already.
310stanger
170
  • Jan 3, 2007
fuel is at 39, timing is 15. thanks for the input, ill check for codes. no check engine light though, so it really never occured to me to check codes.
K
2013 Mustang GT Fuel Injector Question
  • KHills5058
  • Nov 4, 2025
2K
2005 - 2014 S-197 Mustang -General/Talk- Nov 6, 2025
KHills5058
K
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
Fox Mass Air Flow 42lb injectors
  • 89wreck
  • Aug 18, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 5, 2025
Scrapla347
Drivetrain Sticky clutch pedal
  • keel
  • Jul 31, 2025
Fox 5.0 Mustang Tech Oct 17, 2025
Mindseye007
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
