Injector Size?
would i have to worry about daily driving issues with that big of injector? I wont be running more then 8lb. of boost when i get the blower, but for now i want to go with 150 shot of nitrous, i have 19lb injectors right now.
D347643 said:
24 pounders with a 150 shot is fine as lng as you have a high volume fuel pump. im running 24's with 255lph walboro and everything is fine. if you having a blower then def upgrade
Yeah I have a 255 walbro also! cool then ill just go with the 24lb injectors and get a adjustible fuel reg.
Thanks a Ton guys!!!!
if its a wet kit it wont matter as long as you put a big enough fuel jet in .....jet it rich to begin and trim back from there .......friends running a similar set up with 19s and bigger cam ....with 175 shot with no problems .... if its a dry kit then upgrade to the 24s will be fine ......
