Building a 331 with AFR 185's. Should I use 24 or 30 lb injectors. Will be a nitrous car but it's a wet kit. Thanks for any input. Also will probly run a TFS 1 cam, which rockers ??? 1.7 or 1.6 Thanks Fellas
2KsilverGT said:Any recommendations on a cam there GREEN. I just don't want to upgrade the AFR Springs at this point plus I have an AUTO AOD so i'm a little weary about driveability. Thanks bud
While I don't need to buy the meter or tubes, I would be very interested in getting the color codes and diameters of each sample tube from you. I am trying to amass a collection of sample tube colors that is correlated to their respective diameters. This would be pretty helpful to the general Mustang enthusiast, as the color coding is easily removed with assorted solvents/fuels.Beasly B said:I have the sample tubes for 19, 24, and 30lb injectors for the meter, just if your interested.
hi i have almost the same cuestion but i have a 306 with afr 185's, RPM intake, 70 TB, 1 3/4 LT's, comp cams XE274HR, what happen if i use 30pounds with 75mm maff?2KsilverGT said:Building a 331 with AFR 185's. Should I use 24 or 30 lb injectors. Will be a nitrous car but it's a wet kit. Thanks for any input. Also will probly run a TFS 1 cam, which rockers ??? 1.7 or 1.6 Thanks Fellas
Beasly B said:On the sample tubes, vristang, I'll see what I can do this weekend on that info for you, it's a busy weekend, but I'll get it for you.
