- May 8, 2006
- 703
- 240
- 84
Decided to get my code reader out today and try it. My blue car is basically stock with an HP turbo kit, crane ignition and a chip burned by a local tuner. The smog pump and most of the smog equipment has been removed. Ive been reading an old code book (lost the tools book), but its a bit cryptic. I received the bellow results.
Key on engine off
15, 85,10,11
I have that the computer test was good (11), cylinder #1 has some sort of problem (10), cannister purge circuit bad (85), and read only memory bad (15).
I figure the cannister has been removed so am not worried about that one, but dont know where to begin on the others.
Key on engine running
8,21,94,44
No clue on the (8), cooling temp sensor out of range (21) (could be the 180 thermostat?, Air diverter solenoid circuit (94- smog?) and thermactor failure (smog?)
Any input, especially on the #1 cylinder, would be great.
Key on engine off
15, 85,10,11
8,21,94,44
